Hello Guest it is October 17, 2026, 07:56:45 AM
Author Topic: Radius to end of arc differs from start  (Read 19077 times)
« on: November 16, 2020, 02:26:22 PM »
Hi all.
Im   New to cnc. Not been learning for very long. Hit a brick wall. Looked on youtube internet. With no joy how to solve the problem  im drawing a simple arc. In autocad. Saving the file as dxf  then im sending the file to lazy cam i clean it scale it generate the gcode.  I then load code in mach 3 turn mode. and in the screen. It just shows circle. Ive tried it with a diamond shape with a radius   Ive gone to general config and tried changing  ij settings. To absulte and inc.  etc. And same in lazy cam.  And still same shows on screen. What am i doing wrong. Can anyone help.
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: Radius to end of arc differs from start
« Reply #1 on: November 16, 2020, 05:50:05 PM »
Change the IJ mode in config
« Reply #2 on: November 17, 2020, 02:45:11 AM »
I have changed the ij settings in Mach 3 In config and saved changes   I have tried  both settings absolute and inc   And still get same result  a circle in the screen  ??
Offline TPS
  •  2,627 2,627
« Reply #3 on: November 17, 2020, 03:20:26 AM »
can you pls post the dxf and gcode file?
« Reply #4 on: November 17, 2020, 01:11:02 PM »
 the  dxf file  and the g code generated
  •  2,785 2,785
« Reply #5 on: November 17, 2020, 03:54:30 PM »
Are you working in Diameter or Radius mode, Diameter is normal
  •  2,785 2,785
« Reply #6 on: November 17, 2020, 04:16:13 PM »
Try this and see if you get the same as shown here:-
« Reply #7 on: November 18, 2020, 06:20:45 AM »
LazyCam's turn module leaves much to be desired and can be problematic to use. That is one reason that LAZYTURN was created to be a replacement for that module. There is a manual for LazyCam which has a Turn tutorial in it ...... been over 10 years since that was written.
« Reply #8 on: November 18, 2020, 11:08:28 AM »
Hi thanks for reply’s
 I am working in radius ...
 I have read lazy cam manual  but still having issues ,,,,
 I will try that in Mach and see if I get same results  cheers
« Reply #9 on: November 18, 2020, 12:06:18 PM »
Sent your balltap Program to mach3 this is what it throws up
