Hello
Guest
it is
November 23, 2026, 10:17:48 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Radius to end of arc differs from start
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: Radius to end of arc differs from start (Read 19689 times)
Wattsy
6
on:
November 16, 2020, 02:26:22 PM »
Hi all.
Im New to cnc. Not been learning for very long. Hit a brick wall. Looked on youtube internet. With no joy how to solve the problem im drawing a simple arc. In autocad. Saving the file as dxf then im sending the file to lazy cam i clean it scale it generate the gcode. I then load code in mach 3 turn mode. and in the screen. It just shows circle. Ive tried it with a diamond shape with a radius Ive gone to general config and tried changing ij settings. To absulte and inc. etc. And same in lazy cam. And still same shows on screen. What am i doing wrong. Can anyone help.
Logged
Graham Waterworth
2,785
Yorkshire Dales, England
Re: Radius to end of arc differs from start
Reply #1 on:
November 16, 2020, 05:50:05 PM »
Change the IJ mode in config
Logged
Wattsy
6
Reply #2 on:
November 17, 2020, 02:45:11 AM »
I have changed the ij settings in Mach 3 In config and saved changes I have tried both settings absolute and inc And still get same result a circle in the screen ??
Logged
TPS
2,627
Reply #3 on:
November 17, 2020, 03:20:26 AM »
can you pls post the dxf and gcode file?
Logged
Wattsy
6
Reply #4 on:
November 17, 2020, 01:11:02 PM »
the dxf file and the g code generated
Logged
Graham Waterworth
2,785
Reply #5 on:
November 17, 2020, 03:54:30 PM »
Are you working in Diameter or Radius mode, Diameter is normal
Logged
Graham Waterworth
2,785
Reply #6 on:
November 17, 2020, 04:16:13 PM »
Try this and see if you get the same as shown here:-
Logged
Reply #7 on:
November 18, 2020, 06:20:45 AM »
LazyCam's turn module leaves much to be desired and can be problematic to use. That is one reason that LAZYTURN was created to be a replacement for that module. There is a manual for LazyCam which has a Turn tutorial in it ...... been over 10 years since that was written.
Logged
Wattsy
6
Reply #8 on:
November 18, 2020, 11:08:28 AM »
Hi thanks for reply’s
I am working in radius ...
I have read lazy cam manual but still having issues ,,,,
I will try that in Mach and see if I get same results cheers
Logged
Wattsy
6
Reply #9 on:
November 18, 2020, 12:06:18 PM »
Quote from: Graham Waterworth on November 17, 2020, 04:16:13 PM
Sent your balltap Program to mach3 this is what it throws up
Logged
Print
Pages:
1
2
Go Up
« previous
next »
