Hello Guest it is November 24, 2026, 01:11:53 PM
Author Topic: Radius to end of arc differs from start  (Read 19694 times)
Re: Radius to end of arc differs from start
« Reply #10 on: November 19, 2020, 12:11:12 PM »
Does anyone know how I can fix the problem  in Mach 3  ??
Offline TPS
  •  2,627 2,627
« Reply #11 on: November 19, 2020, 01:14:04 PM »
pls post your "Profile".xml file
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
« Reply #12 on: November 20, 2020, 02:21:04 PM »
The code I posted was in Diameter mode so if you change Mach to diameter mode all should look good.
Are you using Radius mode for any special reason, most lathes are programmed Diameter.
