Hello
Guest
it is
October 21, 2026, 09:51:32 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
5 axis
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: 5 axis (Read 22334 times)
Iftikhar Amin
7
5 axis
on:
September 30, 2020, 12:55:21 AM »
Hi group members,
i am encountering an error message when i am loading my 5 axis tooth path. (
No digits found where real number should beline 6).
i am using rhinocam to generate the g code.
please help.
thanks
TPS
2,627
Re: 5 axis
Reply #1 on:
September 30, 2020, 03:30:27 AM »
to be able to help we should see the code.
Iftikhar Amin
7
Re: 5 axis
Reply #2 on:
September 30, 2020, 03:52:48 AM »
thanks for your response.
attached pics is for your reference.
i will send you full g codes if you required.
thanks,
TPS
2,627
Re: 5 axis
Reply #3 on:
September 30, 2020, 03:57:03 AM »
-code file would be great
TPS
2,627
Re: 5 axis
Reply #4 on:
September 30, 2020, 04:03:39 AM »
i Think i found it, ther are two -- in line 6 after A
Iftikhar Amin
7
Re: 5 axis
Reply #5 on:
September 30, 2020, 06:37:35 AM »
ok.
it is generated by the rhinocam.
how i can figure it out.
any suggestion?
TPS
2,627
Re: 5 axis
Reply #6 on:
September 30, 2020, 06:45:03 AM »
i have no idea about rhinocam.
is the code loading, if you edit manualy?
Iftikhar Amin
7
Re: 5 axis
Reply #7 on:
September 30, 2020, 07:03:06 AM »
First i will try to edit this file and see if it works.
what cam software if suitable for 5 axis?
TPS
2,627
Re: 5 axis
Reply #8 on:
September 30, 2020, 07:31:42 AM »
sorry i have no experience with 5-axis machines.
here:
https://www.machsupport.com/forum/index.php?topic=32107.0
is something about a plugin
Iftikhar Amin
7
Re: 5 axis
Reply #9 on:
October 01, 2020, 02:37:58 AM »
i have seen you link regarding 5 axis when opening the link i can not find where to download.
have you tried that link.
please check and tell me.
thanks,
Print
Pages:
1
2
Go Up
« previous
next »
