Hello Guest it is October 21, 2026, 10:00:46 AM
Author Topic: 5 axis  (Read 22339 times)
5 axis
« on: September 30, 2020, 12:55:21 AM »
Hi group members,
i am encountering an error message when i am loading my 5 axis tooth path.  ( No digits found where real number should beline 6).
i am using rhinocam to generate the g code.
please help.
thanks
Offline TPS
  •  2,627 2,627
Re: 5 axis
« Reply #1 on: September 30, 2020, 03:30:27 AM »
to be able to help we should see the code.
Re: 5 axis
« Reply #2 on: September 30, 2020, 03:52:48 AM »
thanks for your response.
attached pics is for your reference.
i will send you full g codes if you required.
thanks,
Offline TPS
  •  2,627 2,627
Re: 5 axis
« Reply #3 on: September 30, 2020, 03:57:03 AM »
-code file would be great
Offline TPS
  •  2,627 2,627
Re: 5 axis
« Reply #4 on: September 30, 2020, 04:03:39 AM »
i Think i found it, ther are two -- in line 6 after A
Re: 5 axis
« Reply #5 on: September 30, 2020, 06:37:35 AM »
ok.
it is generated by the rhinocam.
how i can figure it out.
any suggestion?
Offline TPS
  •  2,627 2,627
Re: 5 axis
« Reply #6 on: September 30, 2020, 06:45:03 AM »
i have no idea about rhinocam.
is the code loading, if you edit manualy?
Re: 5 axis
« Reply #7 on: September 30, 2020, 07:03:06 AM »
First i will try to edit this file and see if it works.
what cam software if suitable for 5 axis?
Offline TPS
  •  2,627 2,627
Re: 5 axis
« Reply #8 on: September 30, 2020, 07:31:42 AM »
sorry i have no experience with 5-axis machines.
here: https://www.machsupport.com/forum/index.php?topic=32107.0
is something about a plugin
Re: 5 axis
« Reply #9 on: October 01, 2020, 02:37:58 AM »
i have seen you link regarding 5 axis when opening the link i can not find where to download.
have you tried that link.
please check and tell me.
thanks,
