Hello Guest it is November 13, 2026, 12:54:23 PM
Author Topic: Only X-axis motor is working  (Read 275576 times)
Offline rcaffin
  •  1,073 1,073
Re: Only X-axis motor is working
« Reply #170 on: April 03, 2018, 04:19:09 PM »
After all this is all a learning process for me.
Oh, it is that for ALL of us!
Keeps me out of my wife's hair, anyhow.
Roger
« Reply #171 on: April 03, 2018, 10:22:19 PM »
Resonance?
I took the 3 amp motor that was working fine on one amp, and hooked it up to 3 amps.
It suffered the same symptoms as the 1 amp motor at one amp.
So... resonance?
How do I keep my new steppers from not doing this?
I'm going to play with underclocking.
Offline rcaffin
  •  1,073 1,073
« Reply #172 on: April 03, 2018, 11:03:29 PM »
There are several ways to deal with resonance - I think I mentioned this earlier.
* Never go near it (stay slow)
* Try to make a mechanical damper to fit on the shaft (negligible likelihood of success)
* Try to damp it down with a toothed belt and a lead-screw (with LOTs of prayers)
* Buy a modern driver which includes electronic resonance damping.
* Use a bi-phase sinewave drive rather than steps. This may or may not succeed, and is almost the same as using a modern high-order micro-stepping driver anyhow.
Roger
« Reply #173 on: April 03, 2018, 11:08:23 PM »
* Never go near it (stay slow) It happens at a very slow speed
* Try to make a mechanical damper to fit on the shaft (negligible likelihood of success) Then I won't bother with it
* Try to damp it down with a toothed belt and a lead-screw (with LOTs of prayers) Then I won't bother with it
* Buy a modern driver which includes electronic resonance damping. In time, in time....
* Use a bi-phase sinewave drive rather than steps. This may or may not succeed, and is almost the same as using a modern high-order micro-stepping driver anyhow. Then I won't bother with it
Roger
In the meantime, I'm going to play with multistepping and/or underclocking. It's possible that my drivers are over amping. I don't have a way to test that.
Offline rcaffin
  •  1,073 1,073
« Reply #174 on: April 03, 2018, 11:24:27 PM »
Multi-stepping is your best chance.
Roger
« Reply #175 on: April 03, 2018, 11:49:43 PM »
Roger
So far multistepping gave the most promising results.
« Reply #176 on: April 04, 2018, 12:44:15 PM »
I did some reading and watching of YouTube videos and have a better understanding of resonance and I am convinced my problem is just that. Resonance.
Now I will be exploring the various methods of removing the resonance factor.
Thanks for pointing me in the right direction.
Offline Davek0974
  •  2,606 2,606
« Reply #177 on: April 04, 2018, 01:27:41 PM »
I wouldn't do too much work if you are not keeping these motors - it will all change with new motors and certainly with new drives ;)
« Reply #178 on: April 04, 2018, 02:25:24 PM »
Point taken.
Anything I do with these motors now is to gain a better understanding of things. I'm not looking for a solution, per second, but more of a path to a solution.
« Reply #179 on: April 07, 2018, 07:22:36 PM »
So, I'm looking at new components to purchase.
(I should start a new thread but this will suffice for now)
The stepper motors I'm planning on using are:
Dual Shaft Nema 23 with rated 439oz.in torque
Full Step Angle:   1.8° (200 Steps)
Rated Current per Phase:   3.5A
Holding Torque:   3.1Nm
Resistance per Phase:   1.1ohms
Wiring Configuration:   4-Wire Bipolar
Nominal Rated Input Voltage:   24 V, 48 V
Actual Rated Input Voltage:   24-48VDC
Power supply:
Wide Range 100-240V AC-DC 600W 48V12.5A
High efficiency, high reliability, low cost.
High 600W power to fit more devices.
Wide range of input voltage support, both of 100-120VAC
200-240VAC input voltage are available(Adjusted By Switch)
Adjustable approx 40-52VDC Output Voltage support.
PWM control and regulation, insure the steady and precise output voltage.
Built-in a powerful fan for cooling.
Built-in EMI filter.
100% full load burn-in test.
Over current, over voltage, short circuit and overheat protections.
Low output ripple and yawp.
Connected with either 16/4 wire or more widely available 18/4 wire.
I will be installing it all with aviation connectors from the control box to the motors.
This should give me the best, solid, system.
After all is assembled and I have a working machine (even if it has bugs) I will update the drivers and controller.
