Hello Guest it is November 13, 2026, 02:53:42 PM
Author Topic: Only X-axis motor is working  (Read 275674 times)
Re: Only X-axis motor is working
« Reply #40 on: March 22, 2018, 02:27:31 AM »
FYI, I bought 2 of these boards because they were cheap.
I was able to get them to drive the steppers after awhile but I was never able to get the analog output for the spindle to work.
I threw them away and purchased a motion control board instead. While I spent a lot of money on a Hiconn (worth every penny) there are less expensive options out there.
Cheap winds up being expensive in the long run.
My .02.
Mike
Offline TPS
  •  2,627 2,627
« Reply #41 on: March 22, 2018, 02:59:10 AM »
cheap or expensive does not matter for the Moment.
without a propper XML None of them has a Chance to work.
« Reply #42 on: March 22, 2018, 03:09:12 AM »
Hi TPS
Agreed.
I just wanted to add in the fact that even after he gets his XML straightened out he may be looking at other problems down the road.
« Reply #43 on: March 22, 2018, 09:01:41 AM »
The cheap BoB is to build the machine, When I'm done building the machine, a better, more reliable BoB will be added. In the meantime, if I did burn up two boards then I'm only out a few bucks.
I am not sure about how to build a new profile for a new XML file but will give it a little effort in learning how. I'm sure it's not technically difficult, just time.
I do have red LEDs. I had a blue one already out. I can switch to red. Not a  big deal. (I bought over a thousand LEDs for a project that was later cancelled).
I appreciate all the assistance.
Offline TPS
  •  2,627 2,627
« Reply #44 on: March 22, 2018, 09:42:21 AM »
just start mach3.exe by doubleclick,
then create new Profile with Standard Parameter.
Offline rcaffin
  •  1,073 1,073
« Reply #45 on: March 22, 2018, 04:35:02 PM »
As TPS said, let Mach do the work. It has the facilities.
Roger
« Reply #46 on: March 22, 2018, 09:11:47 PM »
Just started a blank profile. This should be fun
/sarcasm
« Reply #47 on: March 24, 2018, 12:41:53 AM »
New profile did not yield different results.
Offline TPS
  •  2,627 2,627
« Reply #48 on: March 24, 2018, 02:20:24 AM »
can you post your new XML
« Reply #49 on: March 24, 2018, 01:22:56 PM »
