Hello Guest it is November 13, 2026, 12:32:26 PM
Author Topic: X Y axis move togehter with Arrows key  (Read 66216 times)
« on: February 22, 2018, 02:33:15 AM »
hi in my CNC if I jog the X axis or Y axis both the axis move together ...i.e if up arrow i want to move x axis in + direction Y also moves along same with the Y axis movement and in - direction move.
Please help to resolve this problem.
Thanks in advance
DD
Re: X Y axis move togehter with Arrows key
« Reply #1 on: February 22, 2018, 02:39:10 AM »
you need to check that your step and direction pins are correctly assigned, it sounds like you have both X and Y step inputs being feed from a single signal.
« Reply #2 on: February 23, 2018, 02:19:28 PM »
hi Craig,
Thanks for your reply I was also thinking the same thing but don't know to assign correct pins to step and direction can you elaborate the same enabling me to understand how to assign the right pins? once again thanks for your support i really appreciate it ..
regards,
DD
« Reply #3 on: February 23, 2018, 02:27:57 PM »
Craig Can you give me your email id i'll send all the screen shots of the Mach3 confg. in my machine , easy for you to tell me where I am doing wrong?
regards,
DD
« Reply #4 on: February 23, 2018, 02:57:16 PM »
a screen shot of Machs Ports & Pins Motor page should be enough.
« Reply #5 on: February 24, 2018, 01:10:10 AM »
Rest images I'll send you tonight ...
Offline TPS
  •  2,627 2,627
« Reply #6 on: February 24, 2018, 01:46:50 AM »
can you try to enter a G69 in MDI Input,
just to make sure X/Y plane is not turned.
just a idea
« Reply #7 on: February 24, 2018, 01:48:23 AM »
Ok sir I'll try tonight and will update you..thanks for the support..
« Reply #8 on: February 24, 2018, 02:03:03 AM »
I've had a look at your pin assignments and they look OK.
May I suggest when you post a pic that you crop and resize it with something like 'Paint' so that it will fit on the screen, it helps convey info better.
What I read is:
X axis enabled step= port1 pin 2 dir =port1 pin3
Y axis enabled step=port1 pin 5  dir=port1 pin6
Z axis enabled step=port1 pin 8 dir= port1 pin9
A axis disabled step=port1 pin8 dir=port1 pin9      A duplication, shouldn't matter given that the axis is disabled but confusing, I would correct it.
B axis disabled unassigned
C axis disabled unassigned
Spindle enabled step=port1 pin 17 dir= port1 pin1
Can you confirm? I found it difficult to read the pic having to scan around with the scroll bars.
Thomas's suggestion about checking the active plane is very good.
The other suggestion is that some how you are feeding the same signals to both the X and Y axis drivers. Do you have separate drivers or all on one board?
Offline TPS
  •  2,627 2,627
« Reply #9 on: February 24, 2018, 02:05:58 AM »
also some more Information about the wiring, and used hardware would be helpful.
