Hello Guest it is November 13, 2026, 12:14:00 PM
Author Topic: X Y axis move togehter with Arrows key  (Read 66206 times)
Re: X Y axis move togehter with Arrows key
« Reply #10 on: February 24, 2018, 06:59:21 AM »
I've had a look at your pin assignments and they look OK.
May I suggest when you post a pic that you crop and resize it with something like 'Paint' so that it will fit on the screen, it helps convey info better.
What I read is:
X axis enabled step= port1 pin 2 dir =port1 pin3
Y axis enabled step=port1 pin 5  dir=port1 pin6
Z axis enabled step=port1 pin 8 dir= port1 pin9
A axis disabled step=port1 pin8 dir=port1 pin9      A duplication, shouldn't matter given that the axis is disabled but confusing, I would correct it.
B axis disabled unassigned
C axis disabled unassigned
Spindle enabled step=port1 pin 17 dir= port1 pin1
Can you confirm? I found it difficult to read the pic having to scan around with the scroll bars.
Thomas's suggestion about checking the active plane is very good.
The other suggestion is that some how you are feeding the same signals to both the X and Y axis drivers. Do you have separate drivers or all on one board?
Sorry Craig for the Picture I clicked it from my mobile..next time I'll keep in mind and yes the Pin and ports you wrote are right///regards DD
« Reply #11 on: February 24, 2018, 07:21:03 AM »
I tried G69 nothing happened..Please find enclosed some pictures of controller
« Reply #12 on: February 24, 2018, 07:42:43 AM »
Please find more pictures for your perusal
« Reply #13 on: February 24, 2018, 07:44:03 AM »
Offline TPS
  •  2,627 2,627
« Reply #14 on: February 24, 2018, 08:04:49 AM »
what manufacturer is this controler, any Manual?
« Reply #15 on: February 24, 2018, 08:11:12 AM »
It's Chinese From ...Charmhigh Technology Limited
« Reply #16 on: February 24, 2018, 09:04:21 AM »
No manual
« Reply #17 on: February 24, 2018, 09:16:40 AM »
I just checked in MPG Mode X+ , Y+ , Y- and X- all are working fine....only with the keyboard it's both moving together...
« Reply #18 on: February 24, 2018, 10:13:49 AM »
is your hotkey assignment ok?
Klaus
The brain isn't a soap, it doesn't shrink when used.
« Reply #19 on: February 24, 2018, 11:55:14 AM »
let me check
