Hello Guest it is November 13, 2026, 03:01:30 PM
Author Topic: X Y axis move togehter with Arrows key  (Read 66236 times)
Re: X Y axis move togehter with Arrows key
« Reply #30 on: February 25, 2018, 05:52:38 AM »
yes they are much better.
It looks like your motor outputs are correct.  The layout of the signals suggests
X axis step=pin2
          dir=pin3
Y axis step=pin5
          dir=pin6
Z axis step=pin8
          dir=pin9
Your spindle assignments look wrong
Spindle step=pin16
             dir=pin14
One thing I think you should change is on the Outputs page
X enable=pin4
Y enable=pin4
Z enable=pin4
« Reply #31 on: February 25, 2018, 06:19:17 AM »
Thanks Craig I'll do the same and get back to shortly..
regards,
DD
« Reply #32 on: February 25, 2018, 06:29:24 AM »
I changed the Pin numbers as you suggested but the same condition....
regards,
DD
« Reply #33 on: February 25, 2018, 11:30:38 AM »
I can only conclude that the board is faulty.
Take it up with the peron you bought it from to replace it.
« Reply #34 on: February 26, 2018, 12:40:25 AM »
Hi Craig,
One of my friend also bought the same machine with same controller let me borrow his controller and check on my machine, i'll update you in few hours.
regards,
DD
« Reply #35 on: February 26, 2018, 11:33:31 AM »
I changed the controller and checked the second controller pins configuration it was 100% same as mine and after changing the controller the same result nothing changes How it's possible if my controller is faulty his should be ok ..
« Reply #36 on: February 26, 2018, 11:48:51 AM »
yes that would tend to indicate that Mach is causing the X and Y axes move together.
Try MDIing some separate X and Y moves:
G0 X50
X0
Y50
Y0
That should move X 50mm then back again, then Y 50mm and back again. Does it do that or do both axes move together?
When the axes move together do both the X&Y DROs change together?
Does your friend have his machine set up and running?
« Reply #37 on: February 26, 2018, 12:26:21 PM »
Ok Craig I'll do the same and about my friend he is not using his machine since last 15 days but as per him he was not facing the problem i am facing..
I'll update you tomorrow ..
regards, DD
« Reply #38 on: February 26, 2018, 12:44:16 PM »
could you please put your used profile (xx.XML) here?
Klaus
The brain isn't a soap, it doesn't shrink when used.
« Reply #39 on: February 27, 2018, 01:06:54 AM »
Hi Klaus,
I am not technically sound in this machine so didn't understand can you please elaborate ?
regards,
DD
