Hello Guest it is November 13, 2026, 12:16:10 PM
Author Topic: X Y axis move togehter with Arrows key  (Read 66207 times)
Re: X Y axis move togehter with Arrows key
« Reply #50 on: March 01, 2018, 05:08:59 AM »
Hi Roger
you're rigth. But the profiles I got were opposite. Keys up / down were 39 37 which is x-direction.
Klaus
The brain isn't a soap, it doesn't shrink when used.
Offline rcaffin
  •  1,073 1,073
« Reply #51 on: March 01, 2018, 05:15:50 AM »
Does that explain why X & Y were moving together though?
Strange stuff ...
Roger
« Reply #52 on: March 01, 2018, 05:32:27 AM »
Yes, but only if "Emulated" is also checked.
Klaus
Offline rcaffin
  •  1,073 1,073
« Reply #53 on: March 01, 2018, 02:36:26 PM »
Bugs maybe in the version OP is using?
Roger
« Reply #54 on: March 01, 2018, 02:58:40 PM »
Hi
I don't think so. You can test it with the standard screen 1024.set. Just change the settings, in the "Port Setup and Axis Selection". I tested on Win10 Mach3 V3.043.062 without a parallel port and could see the x and y movement on the DRO's.
Klaus
« Last Edit: March 01, 2018, 03:00:27 PM by Klaus1311 »
Offline rcaffin
  •  1,073 1,073
« Reply #55 on: March 01, 2018, 03:11:47 PM »
Hi Klaus
I am not sure what I should be looking for, or what settings I should be changing. I fiddled around a bit with enabling/disabling the ports on my desk PC but the correct DROs still changed as expected with the arrow keys.
Ah - I do not have a pendant on my desk machine. But the pendant I use on the actual machine works fine.
What am I missing? Suggestions?
Roger
« Reply #56 on: March 01, 2018, 03:27:11 PM »
Hi Roger,
I also don't have a pendant. Try the following:
Ports and Pins -> Input Signals
Jog X++    Enabled Emulated Hotkey 38 (arrow up)
Jog X--      Enabled Emulated Hotkey 40 (arrow down)
Jog Y++    Enabled Emulated Hotkey 39 (arrow right)
Jog Y--      Enabled Emulated Hotkey 37 (arrow left)
Apply
Reset
occasionally I had to change the Jog mode with the fly out dialog
Jogging with the arrow keys up, down, left or riight show x and y movement on the DRO's
Klaus
« Last Edit: March 01, 2018, 03:28:44 PM by Klaus1311 »
« Reply #57 on: March 02, 2018, 09:13:57 AM »
Hi Roger,
Apply
Reset
Klaus
THANKS ALOT KLAUS....PROBLEM SOLVED
« Reply #58 on: March 02, 2018, 09:16:51 AM »
Thanks everyone///Thanks for your support ...Craig , Klaus , Roger ..... problem solved by assigning corresponding  Hotkeys...
