Hello
Guest
it is
November 13, 2026, 11:56:51 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
2010 Screen-Set go to zero
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: 2010 Screen-Set go to zero (Read 9750 times)
Davek0974
2,606
on:
April 03, 2016, 12:11:09 PM »
On the excellent 2010 scree-set goto zero's button, is it possible to edit the commands ?
I find it does Z first which can be dodgy with fixtures etc in the way, would be good to lift Z then move the X & Y
Carnoustie, Scotland
Re: 2010 Screen-Set go to zero
Reply #1 on:
April 03, 2016, 01:08:36 PM »
Never had the 2010 screenset but could it be you do not have a safe Z set in Mach?
Davek0974
2,606
Reply #2 on:
April 03, 2016, 01:14:16 PM »
Possibly, I thought my safe z was zero, will have to check it.
ger21
6,295
Reply #3 on:
April 03, 2016, 01:32:42 PM »
It uses Mach3's built in Goto Zero function.
If you want to change it, you need to use a screen editor to change the function of the button.
Davek0974
2,606
Reply #4 on:
April 03, 2016, 01:35:17 PM »
Ok, thanks, wasn't sure if it was a macro call.
Print
Pages:
1
Go Up
« previous
next »
