Hello Guest it is November 27, 2026, 10:39:17 PM
Author Topic: 2010 Screen-Set go to zero  (Read 9805 times)
Offline Davek0974
  •  2,606 2,606
« on: April 03, 2016, 12:11:09 PM »
On the excellent 2010 scree-set goto zero's button, is it possible to edit the commands ?
I find it does Z first which can be dodgy with fixtures etc in the way, would be good to lift Z then move the X & Y
Re: 2010 Screen-Set go to zero
« Reply #1 on: April 03, 2016, 01:08:36 PM »
Never had the 2010 screenset but could it be you do not have a safe Z set in Mach?
Offline Davek0974
  •  2,606 2,606
« Reply #2 on: April 03, 2016, 01:14:16 PM »
Possibly, I thought my safe z was zero, will have to check it.
« Reply #3 on: April 03, 2016, 01:32:42 PM »
It uses Mach3's built in Goto Zero function.
If you want to change it, you need to use a screen editor to change the function of the button.
Offline Davek0974
  •  2,606 2,606
« Reply #4 on: April 03, 2016, 01:35:17 PM »
Ok, thanks, wasn't sure if it was a macro call.
