Hello Guest it is November 07, 2026, 10:39:11 AM
Author Topic: Lcam 2.0...  (Read 489654 times)
Re: Lcam 2.0...
« Reply #70 on: June 02, 2007, 07:54:39 PM »
You should be able to rotate the drawing if the check the rotate drawing button :)
www.newfangledsolutions.com
www.machsupport.com
Offline docltf
  •  354 354
Re: Lcam 2.0...
« Reply #71 on: June 03, 2007, 08:49:53 AM »
MR Brian
you got me fair and square,i did not notice the new options in the rotate box,pretty goog stuff.you would think
that after trying many selections that i would see it.it would have taken me two weeks to notice it.
thanks bill
Re: Lcam 2.0...
« Reply #72 on: June 03, 2007, 12:19:10 PM »
No trouble :) I was thinking that it was not working ... so it is good news all the way around  ;D
www.machsupport.com
Re: Lcam 2.0...
« Reply #73 on: June 15, 2007, 02:14:13 PM »
ya know what drives me nuts doing a metric project in lcam using inch tools
Wes
Have a nice Day
vmax549
Re: Lcam 2.0...
« Reply #74 on: June 18, 2007, 04:27:33 PM »
Gen Notes:
USing V.076 I cannot access the different layers by clicking on them from the screen they highlight but do not change. I can change the layers from the properties bar ok
Multipass, do we really need to return to and from safe z on each pass?
Leadin? What is the proper size for a lead in? Is it a ratio of the tool diameter? Can we have the default based on a ratio of the tool diam?
Tool table, can we have a reference popup window that accesses Mach's tool table for a reference(this is LAZYCAM correct I get too lazy to go find the tool table catalog for mach(;-) )
Drill holes, If in the tool settings it calls for a step that is less than the max depth can we have a peck drill instead of a straight drill.
           COuld we have an option to create another layer of the drill layer to use for a tapping layer, with the input to set up mach for
           tapping Gcode wise(G95,Feed per rev,Etc., or a spot drill layer , etc.
Good so far (;-) TP
Gcode utility, could we have a simple utility to reoder the line numbers that get mixed up from cutting a pasting and editing the Gcode file.
Re: Lcam 2.0...
« Reply #75 on: June 18, 2007, 10:19:40 PM »
Art or anybody
how do you fix this heart so it will import into lcam.
Wes
Have a nice Day
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: Lcam 2.0...
« Reply #76 on: June 18, 2007, 10:29:44 PM »
Hi Wes
Give these a try loaded into TurboCad 8, Grouped All.
Last Dxf as Drawn by you. Fine after loading in TC and Saving.
Hope this Helps, Chip
« Last Edit: June 18, 2007, 10:35:01 PM by afn09556 »
Re: Lcam 2.0...
« Reply #77 on: July 26, 2007, 08:58:22 AM »
Hi Guys, I used an example DXF for Lazycam Turn and came up with the attached toolpath in Mach 3. It doesn't seem to cut the spirals but Mach 3 Turn always displays them. Mach 3 version R2.3, Radius Mode, Reversed Arcs in Front Post unchecked,Lazycam 2.02 downloaded July 26, 2007. Diameter mode would be much appreciated. Thanks, Glen.
I had a few parts left over - still it's always the same when you try a bit of "do it yourself"
Re: Lcam 2.0...
« Reply #78 on: October 16, 2007, 02:02:17 PM »
Hi group, is there any chance of diameter mode becoming available in LazyCam for lathe ?
Thanks, Glen.
Offline docltf
  •  354 354
Re: Lcam 2.0...
« Reply #79 on: November 18, 2007, 09:47:46 AM »
will there be a import feature for a tap or a text file with out mach3 running in the next release of l-cam.
thanks bill
