Hello Guest it is October 31, 2026, 02:04:29 PM
Author Topic: MR-J2S-A and Mach 3  (Read 80685 times)
Offline sdow
  •  67 67
Re: MR-J2S-A and Mach 3
« Reply #20 on: October 31, 2013, 04:20:20 PM »
i think that tool setter is good gadget when you change tools manual   .
Offline sdow
  •  67 67
« Reply #21 on: October 31, 2013, 05:08:48 PM »
This Topic is not open just for Me and Hood ....other people can answer  for tools tool setter ;)
Offline sdow
  •  67 67
« Reply #22 on: November 01, 2013, 08:45:43 PM »
Hi hood
I have one question for you My drivers  use 1 phase 230V  but is not connected to Magnetic contactor   is  it normal     ? Can hi work with no Magnetic contactor ?
Thinks
« Reply #23 on: November 02, 2013, 05:25:33 AM »
You can connect direct to the mains usually however it is often a good idea to have a contactor to disconnect them but for testing purposes mains should be fine.
Offline sdow
  •  67 67
« Reply #24 on: November 04, 2013, 02:55:57 PM »
Hello Hood
I will go probably with IP-A   ... i need a help   ... how i connect the encoder with to CSMIO ...   In CSMIO have  encoder Z  +  and -  ....?
Thinks
« Reply #25 on: November 04, 2013, 03:15:57 PM »
Most servo drives have an output that passes the encoder signals out of the drive to the controller. Some have to be via emulated outputs, if for example your encoder is a sine/cosine encoder then directly outputting the encoder signal would be no use, so the drive will emulate encoder pulses.
I am not sure what your drives have but I would imagine they would have such signal outputs.
« Reply #26 on: November 04, 2013, 03:20:24 PM »
Ok just had a quick look at the manual and there are line driver outputs for Z, A and B.
See pic below.
Offline sdow
  •  67 67
« Reply #27 on: November 04, 2013, 03:33:59 PM »
if you look the page 9      +Z go to -> pulse Z (J2s)  and  - Z go to -> diff.  Z (J2S)  ?
is it right ?
and page 9   http://www.cs-lab.eu/en/upload/pdf/Conectors%20CSMIO-IP-A.pdf
« Reply #28 on: November 04, 2013, 03:42:29 PM »
see attached pic of how you would connect X axis signals.
Offline sdow
  •  67 67
« Reply #29 on: November 04, 2013, 03:47:23 PM »
if me encoder give 24V   what i can do to connect it  to CSMIO
