Hello Guest it is October 31, 2026, 01:13:01 PM
Author Topic: MR-J2S-A and Mach 3  (Read 80644 times)
Offline sdow
  •  67 67
Re: MR-J2S-A and Mach 3
« Reply #40 on: November 05, 2013, 10:44:51 PM »
Hi Hood
When i put directly 3v to VC  ... my motor not run ?
« Reply #41 on: November 06, 2013, 01:56:14 AM »
Do you have pins 15, 16 and 17 connected to pin 10?
Have you set the parameters in the drive for Speed mode?
Offline sdow
  •  67 67
« Reply #42 on: November 06, 2013, 07:44:29 AM »
yes i connect 15  16 17 to 10   ...but not set the parameters  i can not find this   ?  But, when i connect pin 5 to 10 ...i have torque ?
« Last Edit: November 06, 2013, 07:47:13 AM by sdow »
Offline sdow
  •  67 67
« Reply #43 on: November 06, 2013, 12:23:20 PM »
i put the parameter no.43 -> 0111   no.44 -> 0222 no.45-> 0665 no.46->0770 no.47->0883 no.48-> 0994
battery:  + to VC and - to LG
« Reply #44 on: November 06, 2013, 03:52:59 PM »
Do you have the software for the drive? I think that would make it easier to understand and set parameters. I had a quick look and the ones you mentioned above are the default settings so likely they will need changed to suit whichever mode you are in (Speed, Torque, Position)
Offline sdow
  •  67 67
« Reply #45 on: November 06, 2013, 03:55:17 PM »
yes
« Reply #46 on: November 06, 2013, 03:58:03 PM »
So have you connected the drives up to the software/
Offline sdow
  •  67 67
« Reply #47 on: November 06, 2013, 04:00:41 PM »
i use the page  :  3-6   and  5-2 to 5-3
Offline sdow
  •  67 67
« Reply #48 on: November 06, 2013, 04:01:51 PM »
yes i can run the motor with software in Test -> JOG
Offline sdow
  •  67 67
« Reply #49 on: November 06, 2013, 04:04:55 PM »
if you look in parameter n0.43 to 48    i set it in default .
