Hello Guest it is October 31, 2026, 01:13:03 PM
Author Topic: MR-J2S-A and Mach 3  (Read 80645 times)
Re: MR-J2S-A and Mach 3
« Reply #30 on: November 04, 2013, 03:50:00 PM »
Why do you think it gives out 24v?
It says line driver output and normally that will mean it is 5v. Does it say in the manual that it is 24v?
Offline sdow
  •  67 67
« Reply #31 on: November 04, 2013, 03:56:41 PM »
Because  many inputs is 24v or 10v?
« Reply #32 on: November 04, 2013, 04:17:37 PM »
yes but the I/O for things like enables etc will be 24v but encoder inputs and outputs will almost certainly be 5v.
Offline sdow
  •  67 67
« Reply #33 on: November 04, 2013, 04:55:50 PM »
for  a CNC 3 axis  what you prefer IP-A or IP-S  and why ?   I do not which choose ?
« Reply #34 on: November 04, 2013, 05:06:46 PM »
I have both but the IP-A is preferable to me. Reasons are encoders are fed back to Mach so DROs are updated from encoder position. I switch on, home machine then as long as I keep the logic side of the servo drives powered the DROs in Mach always reflect the axis position.
For example I can disable the servo drives and manually move the axis and the DROs in Mach show the movement.
I can hit a limit switch and the DROs still show the correct position even if the axis moves a bit with inertia.
I can hit the E-Stop and again Mach knows where it is.
With the IP-S or any other controller that does not feed encoders back to Mach then you would need to rehome each time after doing one of the above.
Also you should be aware if disabling a servo or for that matter a stepper you need to re-home when you re-enable it as it has likely moved slightly due to forces such as gravity or belt tension, with the IP-A there is no need for that as it knows exactly how much it moved as the encoders are being monitored.
Offline sdow
  •  67 67
« Reply #35 on: November 04, 2013, 05:34:26 PM »
HI Hood
Can i ask you one other question can you make me one picture  how connect the output  +-10V (  CSMIO ) to driver .
Tomorrow i test all and buy my CSMIO .
Thinks
« Reply #36 on: November 04, 2013, 05:54:41 PM »
VC and LG are the terminals you use on the drive.
Offline sdow
  •  67 67
« Reply #37 on: November 05, 2013, 05:21:06 PM »
Hi Hood
When i connect  my drive and motor to 230V  my motor not have  any power  is very easy to turn it by my hand ... When i turn it  by my hand i can  see the info . of encoders . Is it normal .
Now can i do this ...
Offline sdow
  •  67 67
« Reply #38 on: November 05, 2013, 05:34:15 PM »
LG is it = to GND
Offline sdow
  •  67 67
« Reply #39 on: November 05, 2013, 05:54:09 PM »
