Hello
Guest
it is
November 13, 2026, 03:43:37 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
No response from limit switches
« previous
next »
Print
Pages:
1
2
3
4
5
6
Go Down
Author
Topic: No response from limit switches (Read 67657 times)
Carnoustie, Scotland
Re: No response from limit switches
Reply #30 on:
April 26, 2013, 12:28:36 PM »
That is very strange indeed.
Can you please attach the xml as it is now and I will see if I can find the problem.
Tony Woollacott
67
Reply #31 on:
April 26, 2013, 01:29:57 PM »
Ok, this is it.
Reply #32 on:
April 26, 2013, 04:21:29 PM »
Well it works fine here when I simulate things so I cant understand what is wrong for you.
Looking at your xml it would seem you have Normally Open switches and they are in parallel, is that correct?
Tony Woollacott
67
Reply #33 on:
April 26, 2013, 04:50:03 PM »
They were, but they are now nc and daisy chained.
Reply #34 on:
April 26, 2013, 04:54:55 PM »
Something strange there then, I would expect them to be active High.
What is your limit switch? NC or NO?
Tony Woollacott
67
Reply #35 on:
April 26, 2013, 05:08:16 PM »
either, it depends how they are wired.
Reply #36 on:
April 26, 2013, 05:09:58 PM »
Sorry meant E-Stop, not Limits
Tony Woollacott
67
Reply #37 on:
April 26, 2013, 05:15:21 PM »
Honestly don't know, I would have to go and check. Too late now as I need to run an extension lead down to the garage for light etc. I will only be able to get back to it on Sunday.
Reply #38 on:
April 26, 2013, 05:17:32 PM »
Ok no probs, just you have that active High so I would expect it to be normally closed. However if that is the case then your limits should also be active high unless that BOB does funny things to the signals
Tony Woollacott
67
Reply #39 on:
April 26, 2013, 05:18:46 PM »
I will let you know asap. Thanks for all your time.
Print
Pages:
1
2
3
4
5
6
Go Up
« previous
next »
