Hello Guest it is November 13, 2026, 12:44:43 PM
Author Topic: No response from limit switches  (Read 67637 times)
Re: No response from limit switches
« Reply #10 on: April 22, 2013, 01:26:20 PM »
Ok then that will be your problem if they are Normally Closed, you need Normally Closed in series.
« Reply #11 on: April 22, 2013, 01:28:25 PM »
Ok, I will change them over and let you know what happens. Thanks again.
« Reply #12 on: April 22, 2013, 01:30:16 PM »
to test if you press both you should get a change in LED state on diagnostics page.
« Reply #13 on: April 23, 2013, 12:45:45 PM »
Ok, I am getting the change in led state, but no response from the motors?
« Reply #14 on: April 23, 2013, 12:48:21 PM »
So if you dont press the switches are the LEDs on diagnostics page lit for M1++ etc?
If they are you have the active state wrong.
« Reply #15 on: April 23, 2013, 12:50:42 PM »
no they only light when the switch is depressed.
« Reply #16 on: April 23, 2013, 12:54:25 PM »
Ok so the reset does not flash when you press them?
« Reply #17 on: April 23, 2013, 12:55:26 PM »
no, they have no effect on anything.
« Reply #18 on: April 23, 2013, 12:57:07 PM »
Ok attach your latest xml and also what version of Mach do you have loaded?
« Reply #19 on: April 23, 2013, 12:59:45 PM »
the xml is the one already attached, and I am running the latest version of mach 3.
