Hello Guest it is November 13, 2026, 12:15:20 PM
Author Topic: No response from limit switches  (Read 67625 times)
Re: No response from limit switches
« Reply #20 on: April 23, 2013, 01:01:08 PM »
Ok try an older version of Mach and see if it helps.
« Reply #21 on: April 23, 2013, 01:08:10 PM »
ok I'll give that ago.
« Reply #22 on: April 23, 2013, 01:10:56 PM »
Please get back to me one way or the other, the sooner the better ;)
« Reply #23 on: April 23, 2013, 01:13:22 PM »
Tony, you can find them here.  ftp://anonymous:guest@machsupport.com/  Try 3.043.056
« Reply #24 on: April 23, 2013, 02:14:44 PM »
Thanks Brett, I have tried several of the downloads, but for some reason they all time-out and won't complete. Any suggestions?
« Reply #25 on: April 23, 2013, 02:29:45 PM »
I don't know why they would be timing out unless you security is blocking them.  I could try to email you a zip file.
« Reply #26 on: April 23, 2013, 02:45:32 PM »
Just sent a pm thanks Brett
« Reply #27 on: April 23, 2013, 04:48:08 PM »
One thing still puzzles me. This is the same PC with the same version of Mach 3 working on the same CNC. The only thing that has changed is the BOB and driver boards. ???
« Reply #28 on: April 24, 2013, 01:59:29 AM »
That is the problem with the latest version and the bugs in it, assuming of course that this is your issue. Some people have the issues, some dont, why I have no idea. I do know however that there are many problems with the latest version and a lot more people than normal suffer from them.
« Reply #29 on: April 26, 2013, 10:52:39 AM »
Sorry for the delay I have only just got back to it. I have un-installed my version and re-installed 3.043.056. There is no change. When the switch is made the led lights up, but the axis does not react and the reset does not flash.
