Hello
Guest
it is
October 02, 2026, 05:40:41 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
No response from limit switches
« previous
next »
Print
Pages:
1
2
3
4
5
6
Go Down
Author
Topic: No response from limit switches (Read 65524 times)
Carnoustie, Scotland
Re: No response from limit switches
Reply #10 on:
April 22, 2013, 01:26:20 PM »
Ok then that will be your problem if they are Normally Closed, you need Normally Closed in series.
Tony Woollacott
67
Reply #11 on:
April 22, 2013, 01:28:25 PM »
Ok, I will change them over and let you know what happens. Thanks again.
Reply #12 on:
April 22, 2013, 01:30:16 PM »
to test if you press both you should get a change in LED state on diagnostics page.
Tony Woollacott
67
Reply #13 on:
April 23, 2013, 12:45:45 PM »
Ok, I am getting the change in led state, but no response from the motors?
Reply #14 on:
April 23, 2013, 12:48:21 PM »
So if you dont press the switches are the LEDs on diagnostics page lit for M1++ etc?
If they are you have the active state wrong.
Tony Woollacott
67
Reply #15 on:
April 23, 2013, 12:50:42 PM »
no they only light when the switch is depressed.
Reply #16 on:
April 23, 2013, 12:54:25 PM »
Ok so the reset does not flash when you press them?
Tony Woollacott
67
Reply #17 on:
April 23, 2013, 12:55:26 PM »
no, they have no effect on anything.
Reply #18 on:
April 23, 2013, 12:57:07 PM »
Ok attach your latest xml and also what version of Mach do you have loaded?
Tony Woollacott
67
Reply #19 on:
April 23, 2013, 12:59:45 PM »
the xml is the one already attached, and I am running the latest version of mach 3.
Print
Pages:
1
2
3
4
5
6
Go Up
« previous
next »
