Hello Guest it is October 25, 2026, 08:50:58 AM
Author Topic: Re: Newbie with KL-4030 1st time testing problems  (Read 63404 times)
« on: March 25, 2013, 10:14:17 AM »
I have same problem. But my board is C10 - Bidirectional Breakout Board and the drivers are KL-4030. I turn on everything motors locks but can't get any movement.
  •  9,374 9,374
« Reply #1 on: March 25, 2013, 10:45:45 AM »
Hi Kris,
Welcome to the forum.
Check if you have 5V & EN (on the C10) and CW & CP+ (on the KL-4030) all connected to +5 Volts.
Also that you have a common GND connection between GND (on the C10) and GND (on the KL-4030).
« Reply #2 on: March 26, 2013, 08:18:02 AM »
C10 board
5V and EN connected to 5V. Also the LED light is on.
KL-4030 driver
CW & CP+ what is that? I can't find it on my drivers
  •  9,374 9,374
« Reply #3 on: March 26, 2013, 09:57:04 AM »
Re: Re: Newbie with KL-4030 1st time testing problems
« Reply #4 on: March 26, 2013, 10:02:17 AM »
I used that diagram and that's how I connect everything
« Reply #5 on: March 26, 2013, 10:03:50 AM »
Have you tried enableing sherline half step mode in the config, ports and pins, port set up page?
« Reply #6 on: March 26, 2013, 10:11:58 AM »
No. I will try it and let you know
« Reply #7 on: March 26, 2013, 08:57:48 PM »
I tried it and it still don't work. I have connected Emergency Button and its not working either. Is it possible that I have connected the master switch incorrectly and it won't work? The led is illuminated red when I turn on the power. But when I push in the master switch nothing happens
« Reply #8 on: March 27, 2013, 12:22:34 AM »
Yup, I would say its possible.   I would try one thing at the time.  Get the board powered up and move on form there.  Just take little bites.  Next, get the estop working, then add some inputs if you are useing any, then your outputs to the drives, then your other outputs.  Is the cable your useing from you parallel port a straight thru?
« Reply #9 on: March 27, 2013, 05:09:32 AM »
Yes. I purchase the cable from automationtechnologiesinc .
How to check if I powered everything up if the "master switch" is working correctly?
