Hello Guest it is October 25, 2026, 07:03:51 AM
Author Topic: Re: Newbie with KL-4030 1st time testing problems  (Read 63379 times)
Re: Re: Newbie with KL-4030 1st time testing problems
« Reply #40 on: March 29, 2013, 04:28:41 PM »
The only weird thing it is right now that no matter if I press the master switch or leave it unpressed everything works fine. I thought if I release the master switch then nothing will work
« Reply #41 on: March 29, 2013, 04:43:22 PM »
Do you have to set up the master switch as an estop input?
« Reply #42 on: March 29, 2013, 04:50:32 PM »
No. Estop is set up on different input.
« Reply #43 on: March 29, 2013, 05:06:31 PM »
The C10 I am using came with a very small single strand wire installed as a jumper between the EN and GND terminals. If this connection is open, all outputs should be disabled.
Russ
« Reply #44 on: March 29, 2013, 05:22:01 PM »
That's where I connect the master switch as per wiring diagram. But when I disconnect it it still moving the motors
« Reply #45 on: March 29, 2013, 05:48:01 PM »
Remove everything from those 2 terminals and try it.
There could be something goofy with your switch or wiring.
Russ
« Reply #46 on: March 29, 2013, 05:49:34 PM »
...really, just remove everything from the EN terminal.
There might be something else connected to and relying on the GND terminal.
« Reply #47 on: April 01, 2013, 06:16:55 AM »
I will try that later after work.
