Hello Guest it is November 13, 2026, 04:46:10 PM
Author Topic: Re: Newbie with KL-4030 1st time testing problems  (Read 64683 times)
Re: Re: Newbie with KL-4030 1st time testing problems
« Reply #20 on: March 29, 2013, 10:25:12 AM »
I'm by the machine right now so if somebody can help I will answer right away
« Reply #21 on: March 29, 2013, 10:42:51 AM »
When I put the reading pins to pin 2 & 3 and I try to jog the voltage reading jumps from 5.18 to 5.17-5.16
Once you have that sorted set up pins 2 and 3 for the x axis motor.  Put your meter leads between pins 3 and the one to the left of it 5V/G and see if you get a reading.  Try jogging the x axis in both directions with your meter in place.  You should see your reading change when you change directions.  Look at your x axis dros in machs run screen and see if it counts up and down as you jog in different directions (right and left arrow keys jog the x axis).
I have sent you a PM
« Reply #22 on: March 29, 2013, 10:55:25 AM »
I'm I wrote it wrong. I did put the leads between pins 3 and the 5V. And that was the reading
« Reply #23 on: March 29, 2013, 12:01:15 PM »
Nothing Brett...I gave up :-(
  •  9,377 9,377
« Reply #24 on: March 29, 2013, 12:12:07 PM »
Pysiek,
I take it that you do have a good and stable (regulated) 5 Volt supply connected to your C10 ??
« Reply #25 on: March 29, 2013, 12:14:07 PM »
Yes tweakie. I already check everything with meter
« Reply #26 on: March 29, 2013, 12:18:18 PM »
How do I check if I did not connect the motor cables incorrectly?
On the wiring diagram it shows to use black,green,red and blue wires to connect the motors. But on my motors I have more that
http://www.automationtechnologiesinc.com/wp-content/uploads/downloads/2012/08/KL-4030WithC10.pdf
« Last Edit: March 29, 2013, 12:25:17 PM by Pysiek »
  •  9,377 9,377
« Reply #27 on: March 29, 2013, 12:26:53 PM »
If the C10 is enabled then the motors will 'lock' at system power-up.
(If you have not connected the motors correctly there is a danger of damaging the 4030)
« Reply #28 on: March 29, 2013, 12:31:15 PM »
I did check the wiring again right now and it looks like I did it correctly
« Reply #29 on: March 29, 2013, 12:31:53 PM »
Used that wiring diagram to put the wires together: http://www.automationtechnologiesinc.com/docs/schematics/KL-4030Wiring.pdf
