Hello Guest it is October 21, 2026, 09:47:22 AM
Author Topic: Panasonic servo drive help  (Read 297329 times)
Re: Panasonic servo drive help
« Reply #80 on: March 24, 2013, 09:24:55 AM »
 ;D
Rick, something like this may help.  http://www.ebay.com/itm/2x-Double-Side-Prototype-PCB-Board-5x7-cm-Tinned-Universal-Board-FR4-/130647464585
Not as neat as custom but as long as the spacing is right for your components, should work and be fast enough.  I don't think etching your PCBs would be that bad though.  I think Radio Shack has everything you will need.  You can also have them made with the silk screening and all pretty cheap but for just 1 or 2 it's a lot more expensive than larger quantise.
This is a pretty decent link on etching your own.  http://www.jameco.com/Jameco/PressRoom/makeoneetch.html
You can also machine off the cooper clad insted of etching it off.
Offline rwf71
  •  126 126
« Reply #81 on: March 24, 2013, 09:52:43 AM »
Yea Brett,
    I've seen that done by folks that have a diy cnc machine that works, sure wish I had one. ;D
             Rick
Just a little joke,please don't take offense.
« Reply #82 on: March 24, 2013, 11:07:42 AM »
Rick, I don't even know what your talking about..................  everything looks fine to me.
Yea Brett,
             Rick
 ;D  I know, my point exactly, that's why you've got to hurry up!  You need a CNC to help you build more CNCs.   ;D
Offline rwf71
  •  126 126
« Reply #83 on: March 24, 2013, 11:46:43 AM »
So does this mean I'm not the only one thinking of machine #2 before #1 is finished?
                        Rick
« Reply #84 on: March 24, 2013, 11:54:16 AM »
That's only for the Estop or a drive fault also? And where does it get its signal from?
Dan I am planning to also use the No Fault Out signals on the E-Stop  relay Inputs so if a drive faults it calls an E-Stop. I have not got as far as wiring that section up yet but I think it should work fine. Below is a pic of how this module can be used for multiple E-Stops inputs
Not sure what signal you are referring to in the latter part of your question.
Also the CSMIO monitors the positions of each axis and if one is not where it is meant to be it will call a PID fault and E-Stop all motion, so hopefully I have got a lot of bases covered in the unlikely event that one goes awry.
« Reply #85 on: March 24, 2013, 12:02:25 PM »
Just to add another wee bit, you may see the other safety relay at the side of the red one, it is powered from the start/stop button on my panel, below the E-Stop, see pic.
 What that button does is start the contacters for Drives and coolant however the power for the red E-Stop module is via the relays on it and also the E-Stop to CSMIO/Mach is via the red one. So I can start the computer and have Mach running but I can not take Mach out of reset unless the drives contacters are powered.
« Reply #86 on: March 24, 2013, 12:07:07 PM »
Thanks for the link Hood,
     But DAMN, looks like I really need to learn to make a pcb as the componets you suggest seem to always need one. ::) BTW, that is a really neat, clean  & professional looking electrical cabinet you showed Dan there, looks like I'm getting advise from an EE, I better pay attention!
        Thanks , Rick
I am no EE, I learn every day of new ways and hopefully I will never stop learning. Regarding the PCB's, I often just use vero board to do the  wee boards I need then maybe at a later stage I will route or get a board printed. Pic below of one of the relay boards I made up the the wee lathe.
« Reply #87 on: March 24, 2013, 12:08:50 PM »
                        Rick
Absazactly!  ;D
« Reply #88 on: March 24, 2013, 12:11:37 PM »
Bretts been thinking about that for Years Rick, just he has not managed to complete the 10 million spreadsheets he feels compelled to do before a project ;D
« Reply #89 on: March 24, 2013, 12:52:34 PM »
But I'm at 327,638............ means I'm not too far off from finishing one of them.   ;D
