Hello Guest it is October 21, 2026, 05:58:49 AM
Author Topic: smoothstepper help  (Read 31560 times)
smoothstepper help
« on: February 06, 2013, 06:09:22 PM »
ok so i just got an ethernet smoothstepper, port 1 is working fine. XYZ all home and hit the limit switches.
but cant get port 2 working for the ATC, nothing is happening.
anyone offer any advice?
Offline Jeff_Birt
  •  1,107 1,107
    • Soigeneris
Re: smoothstepper help
« Reply #1 on: February 06, 2013, 06:24:50 PM »
Take a look at the SmoothStepper configuration screen. You will see a setting to change the direction of pins 2-9 to Input or Output. The default in Input. Just change it to output and you'll be all set.
Happy machining , Jeff Birt
« Reply #2 on: February 07, 2013, 02:48:17 AM »
ah must have missed that will take a look many thanks
« Reply #3 on: February 07, 2013, 03:50:58 AM »
http://www.soigeneris.com/Document/Warp9/SmoothStepperUserManualV1.0.pdf
page 5 - its very unclear which what i need to do to change port 2 to an output?
« Reply #4 on: February 07, 2013, 06:18:39 AM »
sorry to pester but can anyone help i really need to get my cnc up and running
« Reply #5 on: February 07, 2013, 06:39:40 AM »
Plugin Control menu then ESS PLugin Config then change the options for whichever ports you want 2-9 to be outputs, they are Inputs as default, see pic.
« Reply #6 on: February 07, 2013, 08:23:53 AM »
why am i struggling to much?!
i setup a new profile for the smoothstepper but all i get the reset flashing it wont let me click it?
ahhh this is turning into a nightmare
Offline Jeff_Birt
  •  1,107 1,107
    • Soigeneris
« Reply #7 on: February 07, 2013, 08:57:46 AM »
Probably because you don't have the EStop input set up correctly. What sort of drives are you using, what kind of breakout board, etc? Can you attach your XML profile?
« Reply #8 on: February 07, 2013, 09:08:15 AM »
ops its cos i didnt have the db25 plugged in.
now my atc which is connected via port 2 on the smoothstepper uses pins 2, 3, 4, 5, 14 and 16
« Reply #9 on: February 07, 2013, 12:24:31 PM »
so am i going to need to tweak the wiring for the atc?
