Hello Guest it is October 20, 2026, 02:52:08 PM
Author Topic: smoothstepper help  (Read 31534 times)
Re: smoothstepper help
« Reply #10 on: February 07, 2013, 12:41:35 PM »
If you configure port 2 to have pins 2-9 as outputs then that will mean you have 1-9, 14 16 and 17 as outputs. If the  pins you mentioned above are all outputs then no need to alter any wiring.
« Reply #11 on: February 07, 2013, 12:44:11 PM »
ummm things still arent working?
XYZ is working perfect.
hood you dont want to remote in and take a look do you?
« Reply #12 on: February 07, 2013, 12:45:44 PM »
Dont know how to do that but if you do then I can try.
« Reply #13 on: February 07, 2013, 12:49:32 PM »
lol, ill be out in the garage after dinner.
google teamviewer, you dont need to install it just run it.
ill give you my ID and password and bosh your in, full control
« Reply #14 on: February 07, 2013, 12:58:02 PM »
ok done.
« Reply #15 on: February 07, 2013, 01:13:34 PM »
will probably be about 8 if thats ok, ill pm you
bugger spindle isnt working either, it starts and stalls instantly
« Reply #16 on: February 09, 2013, 04:43:39 AM »
can anyone help?
im not getting any help over the at ESS forums.
how do you setup a spindle with step and direct?
currently when i m3 the spindle starts and stops instantly and reset in mach flashes
« Reply #17 on: February 09, 2013, 06:58:29 AM »
Sounds like your spindle relays or VFD may be causing noise and tripping the E-Stop. Try putting some filtering in the SS config for the E-Stop, maybe 2 or 3 and see if it helps.
« Reply #18 on: February 09, 2013, 07:39:45 AM »
could you explain further about "putting filtering in the SS config"?
thanks
« Reply #19 on: February 09, 2013, 08:42:22 AM »
Plugin Control menu the ESS Config and enter a value in the filtering box for E-Stop, may even need some in the ther ones as well. Basically it is similar to setting a Debounce Interval in Mach except you have a wee bit more control as you can apply to seperate functions. One thing to note however is in the ESS/USSthe filtering is much more sensitive, where you may have 100 or even 2000 in Machs Debounce Interval the ESS should be low, no more than 10 I would say.
