Hello
Guest
it is
October 21, 2026, 04:52:53 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
smoothstepper help
« previous
next »
Print
Pages:
1
2
3
Go Down
Author
Topic: smoothstepper help (Read 31557 times)
andy_con
123
smoothstepper help
on:
February 06, 2013, 06:09:22 PM »
ok so i just got an ethernet smoothstepper, port 1 is working fine. XYZ all home and hit the limit switches.
but cant get port 2 working for the ATC, nothing is happening.
anyone offer any advice?
Logged
Jeff_Birt
1,107
Re: smoothstepper help
Reply #1 on:
February 06, 2013, 06:24:50 PM »
Take a look at the SmoothStepper configuration screen. You will see a setting to change the direction of pins 2-9 to Input or Output. The default in Input. Just change it to output and you'll be all set.
Logged
Happy machining , Jeff Birt
Check out
www.soigeneris.com
andy_con
123
Reply #2 on:
February 07, 2013, 02:48:17 AM »
ah must have missed that will take a look many thanks
Logged
andy_con
123
Reply #3 on:
February 07, 2013, 03:50:58 AM »
http://www.soigeneris.com/Document/Warp9/SmoothStepperUserManualV1.0.pdf
page 5 - its very unclear which what i need to do to change port 2 to an output?
Logged
andy_con
123
Reply #4 on:
February 07, 2013, 06:18:39 AM »
sorry to pester but can anyone help i really need to get my cnc up and running
Logged
Carnoustie, Scotland
Reply #5 on:
February 07, 2013, 06:39:40 AM »
Plugin Control menu then ESS PLugin Config then change the options for whichever ports you want 2-9 to be outputs, they are Inputs as default, see pic.
Logged
andy_con
123
Reply #6 on:
February 07, 2013, 08:23:53 AM »
why am i struggling to much?!
i setup a new profile for the smoothstepper but all i get the reset flashing it wont let me click it?
ahhh this is turning into a nightmare
Logged
Jeff_Birt
1,107
Reply #7 on:
February 07, 2013, 08:57:46 AM »
Probably because you don't have the EStop input set up correctly. What sort of drives are you using, what kind of breakout board, etc? Can you attach your XML profile?
Logged
Check out
www.soigeneris.com
andy_con
123
Reply #8 on:
February 07, 2013, 09:08:15 AM »
ops its cos i didnt have the db25 plugged in.
now my atc which is connected via port 2 on the smoothstepper uses pins 2, 3, 4, 5, 14 and 16
Logged
andy_con
123
Reply #9 on:
February 07, 2013, 12:24:31 PM »
so am i going to need to tweak the wiring for the atc?
Logged
Print
Pages:
1
2
3
Go Up
« previous
next »
