Hello Guest it is November 13, 2026, 09:40:20 AM
Author Topic: M4a & Mach3 startup ???'s  (Read 35059 times)
« on: November 14, 2012, 02:46:12 PM »
Hello & Help
 We got a new M4a mill & installed the Mach3 software , never got the x4xml file , found one on the net & loaded it . after trying a few things i can get z to home out but x & y just run past the limits . the home switches show they're working .  Any help would be appreciated !!
            Thanks , Steve
Steve
Re: M4a & Mach3 startup ???'s
« Reply #1 on: November 14, 2012, 03:03:33 PM »
When you tested the switches did both the limit AND the home led light up or just the limit led?
« Reply #2 on: November 14, 2012, 04:11:52 PM »
I've tried it both ways with just the home witches & then with x++ & y++ also activated , no luck
Steve
« Reply #3 on: November 14, 2012, 04:15:49 PM »
(;-) You did not answer the question.
« Reply #4 on: November 14, 2012, 04:30:11 PM »
the home#3 lights up
Steve
« Reply #5 on: November 14, 2012, 04:46:58 PM »
When you trip the home for X then Y then Z do they light up the same LED? or different leds ?
« Reply #6 on: November 14, 2012, 05:10:03 PM »
3 different Z=home 1  X=home 2  Y=home3
Steve
« Reply #7 on: November 14, 2012, 06:12:25 PM »
I don't see any logical reason for it NOT to work IF the Homes are showing trips. Perhaps post your XML file and have HOOD take a look see.
« Reply #8 on: November 14, 2012, 07:24:07 PM »
thanks,  i'll post it tomorrow
            steve
Steve
« Reply #9 on: November 14, 2012, 07:29:35 PM »
MIght want to look at home assignment again  I know them as Home1=X  Home2=Y   Home3 =Z
Just a thought, (;-) TP
