Hello Guest it is November 13, 2026, 12:17:16 PM
Author Topic: M4a & Mach3 startup ???'s  (Read 35077 times)
Re: M4a & Mach3 startup ???'s
« Reply #10 on: November 15, 2012, 02:26:39 AM »
As Terry has stated it would seem your pin assignment is wrong for your home switches. In ports and Pins, Inputs. Change X pin for the one Z is using, Change Y for the one X is using and change Z for the one Y is using.
« Reply #11 on: November 15, 2012, 05:00:00 AM »
Thanks i'll try that this afternoon
   Steve
Steve
« Reply #12 on: November 15, 2012, 02:30:33 PM »
Hi Hood !
 I was home and had the wrong info .  X=M1 home   Y=M2 home   Z=M3 home    ,  I attached the xml file here for you that i used,,, thanks for looking !
Steve
« Reply #13 on: November 15, 2012, 02:53:46 PM »
Afraid that is not your xml or it is corrupt, can you try again please.
« Reply #14 on: November 15, 2012, 03:25:41 PM »
See if this works
Steve
« Reply #15 on: November 15, 2012, 03:28:15 PM »
Hood , something is changing , i saved on notepad i'll try sending the internet file
Steve
« Reply #16 on: November 16, 2012, 02:09:14 AM »
Is that the xml you downloaded or the one you are actually using?
There is something weird about it but as yet i have not been able to work out the cause.
If it is the one you downloaded then please attach the one you are actually using.
« Reply #17 on: November 16, 2012, 05:18:16 AM »
Hood , you guys were right , i reversed x home & y home and it correctly homed out . That xml file is the one i started with , just having to try to  get things working one step at a time , next is getting spindle to stay on , command  s100m3 and spindle turns on , runs a couple seconds and stops ,,,,, this is a learning experience !!
Steve
« Reply #18 on: November 16, 2012, 05:43:26 AM »
If you attach the xml you are using now I will see if I can find the spindle issue.
« Reply #19 on: November 16, 2012, 05:51:33 AM »
i'm not at the site , won't be there till 3pm my time , working my day job in a tool room
Steve
