Mach Discussion => General Mach Discussion => Topic started by: sammy556 on November 14, 2012, 03:46:12 PM
Hello & Help
We got a new M4a mill & installed the Mach3 software , never got the x4xml file , found one on the net & loaded it . after trying a few things i can get z to home out but x & y just run past the limits . the home switches show they're working . Any help would be appreciated !!
Thanks , Steve
When you tested the switches did both the limit AND the home led light up or just the limit led?
I've tried it both ways with just the home witches & then with x++ & y++ also activated , no luck
(;-) You did not answer the question.
the home#3 lights up
When you trip the home for X then Y then Z do they light up the same LED? or different leds ?
3 different Z=home 1 X=home 2 Y=home3
I don't see any logical reason for it NOT to work IF the Homes are showing trips. Perhaps post your XML file and have HOOD take a look see.
thanks, i'll post it tomorrow
steve
MIght want to look at home assignment again I know them as Home1=X Home2=Y Home3 =Z
Just a thought, (;-) TP
As Terry has stated it would seem your pin assignment is wrong for your home switches. In ports and Pins, Inputs. Change X pin for the one Z is using, Change Y for the one X is using and change Z for the one Y is using.
Thanks i'll try that this afternoon
Steve
Hi Hood !
I was home and had the wrong info . X=M1 home Y=M2 home Z=M3 home , I attached the xml file here for you that i used,,, thanks for looking !
Afraid that is not your xml or it is corrupt, can you try again please.
See if this works
Hood , something is changing , i saved on notepad i'll try sending the internet file
Is that the xml you downloaded or the one you are actually using?
There is something weird about it but as yet i have not been able to work out the cause.
If it is the one you downloaded then please attach the one you are actually using.
Hood , you guys were right , i reversed x home & y home and it correctly homed out . That xml file is the one i started with , just having to try to get things working one step at a time , next is getting spindle to stay on , command s100m3 and spindle turns on , runs a couple seconds and stops ,,,,, this is a learning experience !!
If you attach the xml you are using now I will see if I can find the spindle issue.
i'm not at the site , won't be there till 3pm my time , working my day job in a tool room
Hood , here's the last xml , thanks for looking at it , I do appreciate the help !!
What kind of spindle motor/driive do you have? You have it set as Step/Dir but you dont have the spindle relays option set.
Hood,
The spindle driver is a Delta VFD-M 220V 1.5kW
Motor is a Mav3 80-4, 1.5hp, 1.1kW, 4 pole, 220V
Thats the best I can do, thanks for your help.
Do you have any info on how the VFD connects to Mach? Any links to a manual download? There has to be some form of spindle control board, that may be built into your control board or may be a seperate component but really need manuals to know.
Hood . i'll send you what i got
found this
You need to set the spindle settings as in the first document, your xml has it set as Step/Dir and it should be PWM, look on page 59.
