Hello Guest it is October 20, 2026, 11:48:25 PM
Author Topic: Digispeed not working  (Read 75391 times)
Re: Digispeed not working
« Reply #50 on: April 12, 2012, 01:56:35 AM »
Hi Mark,
That's what I needed. It shows that the inputs have pullups to 5V. So the MB-02V6 pullup jumper for the inputs need to be set to 5V as well.
Can you also post the manual for the drives that you are using.
Cheers,
Peter
Homann Designs
http://www.homanndesigns.com
email: peter at homanndesigns.com
« Reply #51 on: April 12, 2012, 02:09:15 AM »
Looking at the image in post 42,  You have the inputs pullup jumper set to 0V. You need to set it to the 5V end.
Also the Enable source jumper is set to enable always (pos ON), swap it to the Enable end.(it won't change anything as you have the 3 enable override jumpers in.
Since you limit inputs are active low, you need to go into the Mach3 configuration and ensure that the inputs that are using input pins 10,11,12 and 13 have the active low checkbox ticked.
« Last Edit: April 12, 2012, 02:12:00 AM by Peter Homann »
Homann Designs
Offline otpco
  •  48 48
« Reply #52 on: April 12, 2012, 04:44:45 AM »
here is some more imformation hope this helps thanks again
