Hello Guest it is October 20, 2026, 02:54:46 PM
Author Topic: Digispeed not working  (Read 75313 times)
Offline otpco
  •  48 48
Re: Digispeed not working
« Reply #40 on: April 04, 2012, 11:50:10 PM »
I give up . cant work out how to post a picture any tips
« Reply #41 on: April 05, 2012, 01:14:00 AM »
When trying a reply, there is the addition options at the left on the bottom.
There you can attach the image as a file.
Cheers,
Peter.
Homann Designs
http://www.homanndesigns.com
Offline otpco
  •  48 48
« Reply #42 on: April 05, 2012, 04:10:33 AM »
Here it is I think and hope ! her is my set up the top plug goes to my Rurex 990 boards the bottom from the confuser
« Reply #43 on: April 05, 2012, 04:50:55 AM »
Unfortunately, I can't tell much from the photo, other than you've done a nice wiring job. :)
Can you draw a schematic similar to this.
http://www.homanndesigns.com/pdfs/EN009_V2_3.pdf
Just handdraw it and label the signals.
Cheers,
Peter
Homann Designs
Offline otpco
  •  48 48
« Reply #44 on: April 05, 2012, 07:33:36 AM »
 I will try . it will keep me busy for a while .
Offline otpco
  •  48 48
« Reply #45 on: April 05, 2012, 09:01:22 PM »
 Hi all sorry for the bad pictures  I have my workshop all packed up .I miss my computer with the things I want and use . I have the homman BOB and digi speed working well . I cant get the output to the rutex working . If I plug the two d25 cables together without the BOB it works fine (the Rutex bit ) I cannot get them to both work together . this is how I have them wired thanks Mark
« Reply #46 on: April 11, 2012, 05:21:55 PM »
Hi Mark,
It is very difficult to read the signal labels on the diagram. But, from what I can see you have the step and dir signals coming out from the MB-02 tied to the gnd pins on the R990 DB-25 connector, and the step and dir pins on the R990 db25 connector not connected to the MB-02.
Cheers,
Peter
Homann Designs
Offline otpco
  •  48 48
« Reply #47 on: April 11, 2012, 05:36:07 PM »
sorry peter . what I have is the pins 1 through to 13 on the bob to pins 1 through to pins 13 on the db25
 so pin 1 on the bob to pin 1 on the db25
    pin  2on the bob to pin2 onthe db25   etc etc
so bacisly I want the signals to pass through  If I just plug the two db25 plugs together without the bob in the middle the rutex works (but no digi speed ) if I put the bob in the middle the digi works . what I am trying to get to work is both . maybee I should give you a ring .thanks for your time
« Reply #48 on: April 11, 2012, 07:00:03 PM »
Ok, the MB-02 should certainly allow that.
Do you have the manual for the Rutex Bob and the drives that you are using so I can  have a look at them.
Cheers,
Peter.
Homann Designs
Offline otpco
  •  48 48
« Reply #49 on: April 11, 2012, 07:08:15 PM »
is this what you need
