Hello
Guest
it is
November 13, 2026, 01:33:52 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Mach3 Problems - Rant!!
« previous
next »
Print
Pages:
1
2
3
4
5
6
7
8
9
10
11
12
13
Go Down
Author
Topic: Mach3 Problems - Rant!! (Read 188130 times)
Pinky
48
Re: Mach3 Problems - Rant!!
Reply #60 on:
May 30, 2011, 01:55:54 AM »
I remember asking our machine supplier if they tuned the servo's right, on which they replied, the servo's are pre-tuned from their supplier.
So I really have no idea if it's right or wrong or how to go about checking.
I've attached some documentation on the servo drives we using, it's the 0.75kw flavor.
Appreciate the help
Carnoustie, Scotland
Reply #61 on:
May 30, 2011, 01:59:52 AM »
Servos need to be tuned in place on the machine they will be used on, will go look see what I make of the docs attached.
Reply #62 on:
May 30, 2011, 02:02:32 AM »
That looks like a VFD to me rather than a servo drive, do you have documentation for the axis drives?
Pinky
48
Reply #63 on:
May 30, 2011, 03:18:52 AM »
I asked my manufacturer and this is all I got :
Delta B series .75kw servo motors
Delta AC servo drives
Would that be sufficient?
Reply #64 on:
May 30, 2011, 03:25:20 AM »
A quick google for that and I get a VFD same as you attached the manual for. VFDs are for AC Induction motors and although some can be closed loop it is the speed loop that is closed rather than the position, I think, so I cant see how they will be accurate enough to use in a machine tool for axis drives.
Can you take a pic of your motors and control cabinet internals as that may shed some light onto what you have.
I will read the manual further as I may be wrong about your drives
Reply #65 on:
May 30, 2011, 03:26:59 AM »
Have found this
http://www.delta.com.tw/product/em/motion/motion_servo/motion_servo_main.asp
Are these the types of drives you have and if so which meodels?
Pinky
48
Reply #66 on:
May 30, 2011, 04:21:03 AM »
I'm still waiting on a reply from our manufacturer.
I would imagine it's this one:
http://www.fastltd.net/asd-a2_series-494_en_cd.html
Will supply the exact model number as soon as I get it, but for now I think it's either the ECMA-C10807GS or ECMA-C10807FS
Last Edit: May 30, 2011, 04:23:29 AM by Pinky
Pinky
48
Reply #67 on:
May 30, 2011, 05:57:11 AM »
Ok here is the right info:
http://www.delta.com.tw/product/em/motion/motion_servo/motion_servo_product.asp?pid=2&cid=1&itid=2
model : asd-a0721ab
Hope it helps.
Reply #68 on:
May 30, 2011, 06:52:20 AM »
If you download the manual you can read the tuning section and try the auto tuning.
BR549
6,965
Reply #69 on:
May 30, 2011, 09:03:36 AM »
There is no real way to pretune the servos they HAVE to be tuned ON THE MACHINE . The proper tuning depends on how the servos respond ON the machine . This accounts for friction, sticktion, weight, inertia,velocity, accel, etc
Print
Pages:
1
2
3
4
5
6
7
8
9
10
11
12
13
Go Up
« previous
next »
