Hello Guest it is November 18, 2026, 11:30:09 AM
Author Topic: Hitachi X200  (Read 722547 times)
Re: Hitachi X200
« Reply #100 on: February 02, 2014, 07:44:25 PM »
Nope - just makes it easier to wire.
Re: Hitachi X200
« Reply #101 on: February 05, 2014, 04:46:46 PM »
which settings are correct??
cambosoup99 settings:
A001- 00
A002 – 02
A004- 400HZ (THIS NEEDS TO BE SET FIRST, BEFORE THE VFD WILL LET YOU CHANGE A003
A003 – 400Hz
A061 – 400HZ
A062 – 0 (THIS THE LOWEST FREQUENCY THAT YOU WANT YOUR SPINDLE TO RUN, YOUR CHOICE, I’M USING 0 FOR FULL RANGE)
A082 – 230V
A151- 0
A152 – 400HZ
A153 – 0
A154 – 100
A155 - 00
B012 – 10 (8 TO 10 AMPS DEPENDING ON YOUR SPINDLE)
H003 – 2.2 KW (this is your spindle kw rating)
H004 - 2 poles
or these ones suggested by diyengineer.
A001 = 03
A002 = 03
B089 = 01
C070 = 03
C071 = 06
C072 = 1
C074 = 00
C075 = 1
C076 = 02
C077 = 0
C078 = 0
I load a Gcode and run it and the VFD doesnt show the frecuency change
thanks
« Last Edit: February 05, 2014, 04:49:48 PM by Bartok »
Re: Hitachi X200
« Reply #102 on: March 26, 2014, 09:08:24 AM »
Up and running Hitachi X200 thru Mach3 ( Modbus ). Having 2 issues.... First issue is on rpm setting in mach3 does on match hz setting on VFD ( 12000rpm shows 280hz on vfd ) My second issue is, how can you delay z axis from dropping down to start cutting ( as the spindle motor is not up to full rpm yet )
Re: Hitachi X200
« Reply #103 on: March 26, 2014, 09:17:33 AM »
Not sure about the first issue, maybe set up a scaling factor in the drive parameters ? ? ?
2nd issue, Config/Ports and Pins/ Spindle Setup/ Set the Spinup delay accordingly.
Russ
Re: Hitachi X200
« Reply #104 on: March 26, 2014, 04:11:32 PM »
Russ
First issue resolved itself, thanks for the information on setting up the delay.
Re: Hitachi X200
« Reply #105 on: March 26, 2014, 04:15:24 PM »
That's good to hear, happy to help.
Russ
Offline Op4
  •  2 2
Re: Hitachi X200
« Reply #106 on: March 28, 2015, 04:33:43 PM »
Just wanted to follow up that you can use USB to Serial converter as long as it is isolated.  I used http://www.amazon.com/gp/product/B0093QEOJ0/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
I know its spendy, but this allows me to use my laptop for controlling the x200 using the settings here.  Works perfect.  I tried two other usb to serial converters and they did not work.
Re: Hitachi X200
« Reply #107 on: February 26, 2026, 12:17:49 AM »
15 years later and this still works! Just got my x200 VFD set up with modbus in mach 3  ;D ;D ;D ;D
Re: Hitachi X200
« Reply #108 on: February 26, 2026, 06:45:36 PM »
Good to hear.  Modbus in Mach3 is rock solid.
Peter.
Homann Designs
http://www.homanndesigns.com
email: peter at homanndesigns.com
