Hello Guest it is November 14, 2026, 04:27:53 PM
Author Topic: why won't this macro work??  (Read 12642 times)
« on: June 30, 2010, 10:23:59 AM »
Hello
Im getting a "compile error" message
If Not IsActive (input4) Then   <<< will work if i get rid of this line
Code "G1 X 0.020"
While ismoving
sleep (1000)
setDro (0,0)
any Ideas??
thanks
Josh
Offline stirling
  •  2,188 2,188
  • UK
    • www.razordance.co.uk
Re: why won't this macro work??
« Reply #1 on: June 30, 2010, 10:26:42 AM »
you need an "end if" in there.
Ian
« Reply #2 on: June 30, 2010, 10:29:55 AM »
Yes Sir!! now it works thanks
Code "G1 X 0.020"
While ismoving
sleep (1000)
setDro (0,0)
end if
Offline stirling
  •  2,188 2,188
  • UK
« Reply #3 on: June 30, 2010, 10:59:05 AM »
might want to stick a "wend" after your sleep too. When your input goes inactive you'll likely get a syntax error. Also stick a () on the end of your isMoving (it's a function) not a sub.
Ian
« Reply #4 on: June 30, 2010, 11:26:46 AM »
Code "G1 X 0.020"
While ismoving ()
Wend
sleep (1000)
setDro (0,0)
end if
Hows this?
Offline stirling
  •  2,188 2,188
  • UK
« Reply #5 on: June 30, 2010, 01:21:12 PM »
well you could stick it before the sleep but after would be better  ;D
