Hello
Guest
it is
November 14, 2026, 04:18:41 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
why won't this macro work??
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: why won't this macro work?? (Read 12638 times)
learman
93
on:
June 30, 2010, 10:23:59 AM »
Hello
Im getting a "compile error" message
If Not IsActive (input4) Then <<< will work if i get rid of this line
Code "G1 X 0.020"
While ismoving
sleep (1000)
setDro (0,0)
any Ideas??
thanks
Josh
Logged
stirling
2,188
UK
Re: why won't this macro work??
Reply #1 on:
June 30, 2010, 10:26:42 AM »
you need an "end if" in there.
Ian
Logged
Razordance Torch Height Control
learman
93
Reply #2 on:
June 30, 2010, 10:29:55 AM »
Yes Sir!! now it works thanks
Code "G1 X 0.020"
While ismoving
sleep (1000)
setDro (0,0)
end if
Logged
stirling
2,188
UK
Reply #3 on:
June 30, 2010, 10:59:05 AM »
might want to stick a "wend" after your sleep too. When your input goes inactive you'll likely get a syntax error. Also stick a () on the end of your isMoving (it's a function) not a sub.
Ian
Logged
learman
93
Reply #4 on:
June 30, 2010, 11:26:46 AM »
Code "G1 X 0.020"
While ismoving ()
Wend
sleep (1000)
setDro (0,0)
end if
Hows this?
Logged
stirling
2,188
UK
Reply #5 on:
June 30, 2010, 01:21:12 PM »
well you could stick it
before
the sleep but
after
would be better
Logged
Print
Pages:
1
Go Up
« previous
next »
