Mach Discussion => General Mach Discussion => Topic started by: learman on June 30, 2010, 11:23:59 AM
Hello
Im getting a "compile error" message
If Not IsActive (input4) Then <<< will work if i get rid of this line
Code "G1 X 0.020"
While ismoving
sleep (1000)
setDro (0,0)
any Ideas??
thanks
Josh
you need an "end if" in there.
Ian
Yes Sir!! now it works thanks
Code "G1 X 0.020"
While ismoving
sleep (1000)
setDro (0,0)
end if
might want to stick a "wend" after your sleep too. When your input goes inactive you'll likely get a syntax error. Also stick a () on the end of your isMoving (it's a function) not a sub.
Ian
Code "G1 X 0.020"
While ismoving ()
Wend
sleep (1000)
setDro (0,0)
end if
Hows this?
well you could stick it before the sleep but after would be better ;D
