Hello Guest it is October 24, 2026, 06:29:07 PM
Author Topic: Saving Fixture Offsets  (Read 10752 times)
« on: June 17, 2010, 10:56:06 PM »
Hi
Is there a way to save the fixture offsets from vb.  I have tried DoOEMButton(122), but this still requires you to press the save button.  I am setting my offsets with setVar(5241), but then I am wanting to save the changes.
Andrew
Re: Saving Fixture Offsets
« Reply #1 on: June 18, 2010, 12:34:59 AM »
Have you tried using persistant offsets in the config general section? that should auto save the offsets.
Other than that I don't know of a way.
« Reply #2 on: June 18, 2010, 12:57:29 AM »
Hi
Thanks for your reply.  I have persist offsets ticked, but still no joy. I have tried .DoMenu(1,14) but that doesn't work either.
Regards
Andrew
« Reply #3 on: June 20, 2010, 11:52:50 AM »
Andrew have you tried using SENDKEYS to allow VB to push the buttons on the screen?
Offline Tarak
  •  229 229
« Reply #4 on: June 21, 2012, 05:48:37 PM »
Hi, did you guys have any luck with the VB code?
I've tried to set a button to save the offsets, so if there is power out, I can start back up and it's got the correct coords after I reference the machine.
