Hello
Guest
it is
October 24, 2026, 08:26:49 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Saving Fixture Offsets
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Saving Fixture Offsets (Read 10754 times)
babinda01
32
on:
June 17, 2010, 10:56:06 PM »
Hi
Is there a way to save the fixture offsets from vb. I have tried DoOEMButton(122), but this still requires you to press the save button. I am setting my offsets with setVar(5241), but then I am wanting to save the changes.
Andrew
Logged
BR549
6,965
Re: Saving Fixture Offsets
Reply #1 on:
June 18, 2010, 12:34:59 AM »
Have you tried using persistant offsets in the config general section? that should auto save the offsets.
Other than that I don't know of a way.
Logged
babinda01
32
Reply #2 on:
June 18, 2010, 12:57:29 AM »
Hi
Thanks for your reply. I have persist offsets ticked, but still no joy. I have tried .DoMenu(1,14) but that doesn't work either.
Regards
Andrew
Logged
BR549
6,965
Reply #3 on:
June 20, 2010, 11:52:50 AM »
Andrew have you tried using SENDKEYS to allow VB to push the buttons on the screen?
Logged
Tarak
229
Reply #4 on:
June 21, 2012, 05:48:37 PM »
Hi, did you guys have any luck with the VB code?
I've tried to set a button to save the offsets, so if there is power out, I can start back up and it's got the correct coords after I reference the machine.
Logged
Print
Pages:
1
Go Up
« previous
next »
