Hello Guest it is October 19, 2026, 01:46:54 PM
Author Topic: Stragen events question  (Read 92307 times)
Offline NormB
  •  169 169
  • Norm
Re: Stragen events question
« Reply #50 on: January 18, 2010, 06:45:21 PM »
Oh my, I just thoght of something.  The computer has a wireless mouse and keyboard and the ocntroller was between them.........next to the sending unit..............?????  That is a radio freq. not sure how hight but it can be noise....
« Reply #51 on: January 18, 2010, 06:48:10 PM »
Could be the keyboard but  I am thinking most likely the  plugs  maybe had a bad contact. maybe a slight  bit of corrosion on them and swapping them has scraped it off, hopefully its all cured now, time will tell.
Offline NormB
  •  169 169
  • Norm
« Reply #52 on: January 18, 2010, 06:51:19 PM »
I hope this is not normal for these.  This will drive you wacky........I guess I need to run it as is moving the controller away from the computer and see what happens.  I suppose I can move it back to where I had it and run again to see if it acts up that would tell if it's the keyboard or not.
« Reply #53 on: January 18, 2010, 06:55:09 PM »
yes thats probably what I would do as well, I hate not to know what went wrong, almost as bad as it still happening ;D
Offline NormB
  •  169 169
  • Norm
« Reply #54 on: January 18, 2010, 06:56:10 PM »
I also set Zero for Z with a block and at the end of the run I checked to see if it returned to Zero and yes it did.  Trying to make sure it didn't loose steps.  Can the router noise do something like this I did not have the router running for this test just the drives so I could hear them.
Offline NormB
  •  169 169
  • Norm
« Reply #55 on: January 18, 2010, 06:57:21 PM »
Exactly if you know what went wrong you can fix it........but this is a devil waiting to surface again.  that is my fear........not knowing is scary..........
« Reply #56 on: January 18, 2010, 06:58:36 PM »
Ah yes, router could well produce a lot of noise, does it have brushes? If so check to see they are good condition.
Offline NormB
  •  169 169
  • Norm
« Reply #57 on: January 18, 2010, 07:03:41 PM »
This router only has a few hours on it......it's a roybe 2 3/4 horse.......I will check but they really should be fine.  For noise you are looking for a chatter or freq. type noise right......like a bad high speed bearing and it's squeal.  Radio noise something like that brushed arching will make a lot of noise I can make sure they are tight and in good condition it's a thing to look at.......
Offline NormB
  •  169 169
  • Norm
« Reply #58 on: January 18, 2010, 07:06:25 PM »
You know that is not correct it's a bosch router but it is 2 3/4 horse........I don't think make has mch to do with it if the brushed are okay or not is the issue.
« Reply #59 on: January 18, 2010, 07:09:24 PM »
Probably the best bet is do a few more tests in the same position but with the router running, if its ok then put it back where it was and try a few more, if all is still good then it would seem the likely cause was the connectors.
