Hello Guest it is November 13, 2026, 08:06:15 PM
Author Topic: long program glitch  (Read 50824 times)
long program glitch
« on: December 06, 2009, 04:52:14 PM »
hi folks im woundering if any one can help me
im using vetric pro software
mach3 os for the operating software on a 2009 camwood wr408
all software is reg and updated current as of july of this year
here is my problem
if i am doing any thing simple ie:shapes drill cycles generar routing ect my machine runs like a swiss watch
when i try to do a complex art rout ie something that has many tools and thousands of lines i get emergency stops
tool crashes and all sorts of different glitches
i will note that i do not have an automatic tool changer so i work around it by telling the etric software different tools
i have for example tried to run long programs slowes to allow the controler to keep up this did nothing
i think the interface between the computer and the machine is called a soft stepper3
any ideas on what i might be doing wrong would help
thank you guys and gals in advance
Offline gdb
  •  6 6
Re: long program glitch
« Reply #1 on: December 06, 2009, 05:06:15 PM »
Hi sledrat, I had strang things going on with large 3d files. I turned off the ToolPath window on the Diagnostics page lower left corner
 and fixed the problem.
       Glen
« Reply #2 on: December 06, 2009, 05:08:53 PM »
i have tried that to no resolve
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
« Reply #3 on: December 06, 2009, 05:09:13 PM »
do you have micro switches as limit switches?
When you get the e-stop errors is the machine juddering or vibrating ?
Do you get the errors more during 3 axis simultaneous moves ?
« Reply #4 on: December 06, 2009, 05:16:17 PM »
e stops are not limit switches
not getting e stop errors at tool change i get an emergency once in a while but the machine has already stopped
Offline rcrabb
  •  146 146
« Reply #5 on: December 06, 2009, 05:50:37 PM »
can you run the file with no machine conected? This should rule out software errors
Ryan
« Reply #6 on: December 06, 2009, 05:53:01 PM »
i dont know how
Offline rcrabb
  •  146 146
« Reply #7 on: December 06, 2009, 05:58:01 PM »
Can you post the file your trying to run and your XML file?
Ryan
« Reply #8 on: December 06, 2009, 06:01:06 PM »
i will try in a few min.
« Reply #9 on: December 06, 2009, 06:08:06 PM »
hey i just tried to post the file
the fourm said to many char
the prog is abou 6000 lines long
