Hello Guest it is November 13, 2026, 08:09:16 PM
Author Topic: long program glitch  (Read 50826 times)
Re: long program glitch
« Reply #20 on: December 06, 2009, 06:51:00 PM »
stop  for a tool change but that is when truble happens
i would like to enter the offsets page change tools and hit the start cycle and walk away for the next 20 min.
but what i get is the machine stops then either before or after i go to the offset page to change tools
i get an emergency
« Reply #21 on: December 06, 2009, 06:55:41 PM »
You  say you get an emergency, what exactly does the  message say?
 I am running your file at the moment in simulation and seems good so far.
« Reply #22 on: December 06, 2009, 06:57:23 PM »
in the space next to reset it says emergency and scrools rite to left repeating
« Reply #23 on: December 06, 2009, 06:58:23 PM »
hey by the way i want to thank you for your help
« Reply #24 on: December 06, 2009, 07:04:01 PM »
Cant recall ever seeing emergency on its own, will have to think about that and try a few things to see if I can simulate it.
As Ryan has said, your xml might throw up some answers, so when you get a chance attach your xml, you will find it in the main Mach3 folder and if you are using the standard profile it will be called Mach3Mill.xml, if you have a custom profile then it will have that name. You will likely need to change the name of it before you can attach to the forum so once you have it on your pen drive change the name to sledrat.xml and the forum should accept it fine.
« Reply #25 on: December 06, 2009, 07:08:49 PM »
hey i have seen that my file i belive it is the standard
i have seen the file mach3mill.xml some where on the cnc pc
Offline rcrabb
  •  146 146
« Reply #26 on: December 06, 2009, 07:11:12 PM »
The file is running perfect for me
Ryan
« Reply #27 on: December 06, 2009, 07:14:59 PM »
i guess that tells me mine might have an issue
can you tell me the correct way to deal with vetricthat uses different tools
and my machine that does not have a tool changer or at least tell me what is supposed to happen
« Reply #28 on: December 06, 2009, 07:15:34 PM »
runs fine for me as well.
What are the specs of your computer (sorry if you already said but its after 1am here and my eyes are tired :D )
What version of Mach are you running?
« Reply #29 on: December 06, 2009, 07:19:06 PM »
Normally you have Mach configured to stop at a tool change  and when you have swapped the tool you press start and Mach will continue with the new offset. Mach gets the offsets from the tooltable.
 I have a knee mill so dont worry about that as I just wind the knee to suit rather than have tools in the tooltable as its quicker for me.
