Hello Guest it is November 13, 2026, 08:08:20 PM
Author Topic: long program glitch  (Read 50825 times)
Re: long program glitch
« Reply #30 on: December 06, 2009, 07:20:54 PM »
or do you know of a simple do nothing file that would involve multiple tool changes i could run as an example
that way i eould know what to expect or at least know ho to modify my txt file to suit my machine
about the onle code i use now is g64 constant vel so its not to hard on my machine
Offline rcrabb
  •  146 146
« Reply #31 on: December 06, 2009, 07:23:48 PM »
Is your machine set to stop at tool change? This is a setting in general config.
Ryan
« Reply #32 on: December 06, 2009, 07:24:55 PM »
i dont use the tool table because i am running only a few bits and on my machine when ever you change to a different tool number it brings up a pop up that says you can only have tool num 1
« Reply #33 on: December 06, 2009, 07:25:31 PM »
yes its supposed to
« Reply #34 on: December 06, 2009, 07:35:26 PM »
hey guy i want to thank you again
tommorow i am going to try to program a simple fileand try different tool changes
and i am going to check all my settings if i read your post rite its late where ever you are from
get to sleep
Offline rcrabb
  •  146 146
« Reply #35 on: December 06, 2009, 07:37:32 PM »
Grab your XML. I also PM you my email if you need more help.
Ryan
