Hello Guest it is October 20, 2026, 08:50:15 PM
Author Topic: Current list of G & M Codes for Lathe  (Read 29951 times)
« on: September 22, 2009, 06:02:29 AM »
Anyone know where i can get them, done a search but drew a blank
Phil
Re: Current list of G & M Codes for Lathe
« Reply #1 on: September 22, 2009, 09:57:39 AM »
Turn manual is the only place I can think of.
« Reply #2 on: September 22, 2009, 10:41:52 AM »
Don't think such a thing exists. Like Hood said, the Turn manual is the closest thing, but it doesn't mention some codes - like the CSS for instance.
Daniel
« Reply #3 on: September 23, 2009, 03:29:34 AM »
The reason i asked is i was going to make a list for use on the lathe screen similar to what is available for Mill
Phil
« Reply #4 on: September 23, 2009, 05:17:42 AM »
The Using Mach3TURN MANUAL has a listing, and it includes in the listing lists the Gcode ( associated macro ) for G77  ( M1077.MIS ) and G78 ( M10778.MIS ). If it dosen't list it there I'll  assume that it's not supported.
« Reply #5 on: September 23, 2009, 06:24:37 AM »
As Daniel previously mentioned the only one I can think of that is not in the manual is G48S**** which is used to limit the spindle speed when in CSS.
« Reply #6 on: September 23, 2009, 06:37:09 AM »
Thanks Hood,
 I created a "cheat cheat" listing of the Gcodes and which will be in an appendix of the LazyTurn Manual. Made a note to include the G48S.
« Reply #7 on: September 23, 2009, 06:57:51 AM »
Along with G96 and G97.
I think there were couple of other codes also, but can't remember now.
Daniel
« Reply #8 on: September 23, 2009, 07:01:32 AM »
Daniel, G96 and G97 are in the manual, possibly not in the list but they are there.
« Reply #9 on: September 23, 2009, 07:03:46 AM »
Just had a look, its section 6.2.3.1 of th turn manual, certainly doesn't go into much detail though.
