Hello Guest it is October 20, 2026, 03:05:12 PM
Author Topic: Current list of G & M Codes for Lathe  (Read 29925 times)
Re: Current list of G & M Codes for Lathe
« Reply #10 on: September 23, 2009, 07:09:01 AM »
Hood,
Ok, they ARE mentioned in the manual, but not under the section you'd expect them to be. They are not in the list (like you you noted) or the gcode section, and only mentioned on page 6-2.
Daniel
« Reply #11 on: September 23, 2009, 07:10:48 AM »
Was typing when you posted your reply ;)
Daniel
« Reply #12 on: September 23, 2009, 07:42:24 AM »
The Using Mach3TURN MANUAL has a listing, and it includes in the listing lists the Gcode ( associated macro ) for G77  ( M1077.MIS ) and G78 ( M10778.MIS ). If it dosen't list it there I'll  assume that it's not supported.
Hi Rich
Just had a look and couldn't find it
Phil
« Reply #13 on: September 23, 2009, 07:46:21 AM »
Hi Rich
Phil
Pg 10-10 and 10-17
« Reply #14 on: September 23, 2009, 08:08:14 AM »
Sorry i thought it was in the LazyTurn Manual
Where do i find the Mach3TURN MANUAL  ::)
Phil
« Reply #15 on: September 23, 2009, 08:11:02 AM »
Support link at the top of the page.
« Reply #16 on: September 23, 2009, 08:39:09 AM »
Sorry, but the LazyTurn manual is still in developement like the software.  :)
