Hello
Guest
it is
November 16, 2026, 07:23:39 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
No jogging now
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: No jogging now (Read 17085 times)
M250cnc
591
No jogging now
on:
September 09, 2009, 06:13:41 AM »
Hi i have been doing some screen designing "Standard Lathe Screen" and now the manual jogging has stopped working
I can use the jog toggle button to change to mpg and this will work with my mpg
I change screens and jogging works again
Any ideas ?
Phil
ger21
6,295
Re: No jogging now
Reply #1 on:
September 09, 2009, 06:32:02 AM »
You need a jog on/off button on the screen to allow jogging.
M250cnc
591
Re: No jogging now
Reply #2 on:
September 09, 2009, 06:37:12 AM »
Jogging on off defiantly there, i have moved it to page 0 surely that wouldn't make a difference.
Phil
ger21
6,295
Re: No jogging now
Reply #3 on:
September 09, 2009, 08:00:01 AM »
It has to be on
every
page you want to jog on.
M250cnc
591
Re: No jogging now
Reply #4 on:
September 09, 2009, 08:26:59 AM »
Done some more testing it does indeed stop working.
So what is the solution
Last Edit: September 09, 2009, 09:09:52 AM by Phil_H
ger21
6,295
Re: No jogging now
Reply #5 on:
September 09, 2009, 09:08:43 AM »
Quote from: Phil_H on September 09, 2009, 08:26:59 AM
I put it back on a page but it still doesn't jog.
Are you sure it's not in MPG mode?
M250cnc
591
Re: No jogging now
Reply #6 on:
September 09, 2009, 09:12:14 AM »
I have put a led to know what mode its in. it WILL work in MPG mode with an mpg not not jog cont.
Please look at an edited reply above
ger21
6,295
Re: No jogging now
Reply #7 on:
September 09, 2009, 09:16:56 AM »
Now I'm confused after you edited your posts. If you have a Jog on/off button on the current page, and you're in the correct jog mode, it should jog.
M250cnc
591
Re: No jogging now
Reply #8 on:
September 09, 2009, 09:23:43 AM »
Hi i have now solved the issue with the clues you provided
I am using the fantastic Machscreen program
I checked the button properties for the jog button on an individual page it had global set to NO
On the page i have the button it is a global page "0" i changed the buttons properties from global Yes to global NO and now it is working
Phil
Last Edit: September 09, 2009, 09:31:55 AM by Phil_H
Print
Pages:
1
Go Up
« previous
next »
