Mach Discussion => General Mach Discussion => Topic started by: M250cnc on September 09, 2009, 07:13:41 AM
Hi i have been doing some screen designing "Standard Lathe Screen" and now the manual jogging has stopped working
I can use the jog toggle button to change to mpg and this will work with my mpg
I change screens and jogging works again
Any ideas ?
Phil
You need a jog on/off button on the screen to allow jogging.
Jogging on off defiantly there, i have moved it to page 0 surely that wouldn't make a difference.
Phil
It has to be on every page you want to jog on.
Done some more testing it does indeed stop working.
So what is the solution ;D
I put it back on a page but it still doesn't jog.
Are you sure it's not in MPG mode?
I have put a led to know what mode its in. it WILL work in MPG mode with an mpg not not jog cont.
Please look at an edited reply above
Now I'm confused after you edited your posts. If you have a Jog on/off button on the current page, and you're in the correct jog mode, it should jog.
Hi i have now solved the issue with the clues you provided
I am using the fantastic Machscreen program
I checked the button properties for the jog button on an individual page it had global set to NO
On the page i have the button it is a global page "0" i changed the buttons properties from global Yes to global NO and now it is working
Phil
