Hello Guest it is October 22, 2026, 02:02:50 PM
Author Topic: No jogging now  (Read 16677 times)
No jogging now
« on: September 09, 2009, 06:13:41 AM »
Hi i have been doing some screen designing "Standard Lathe Screen" and now the manual jogging has stopped working
I can use the jog toggle button to change to mpg and this will work with my mpg
I change screens and jogging works again
Any ideas ?
Phil
Re: No jogging now
« Reply #1 on: September 09, 2009, 06:32:02 AM »
You need a jog on/off button on the screen to allow jogging.
Re: No jogging now
« Reply #2 on: September 09, 2009, 06:37:12 AM »
Jogging on off defiantly there, i have moved it to page 0 surely that wouldn't make a difference.
Phil
Re: No jogging now
« Reply #3 on: September 09, 2009, 08:00:01 AM »
It has to be on every page you want to jog on.
Re: No jogging now
« Reply #4 on: September 09, 2009, 08:26:59 AM »
Done some more testing it does indeed stop working.
So what is the solution  ;D
« Last Edit: September 09, 2009, 09:09:52 AM by Phil_H »
Re: No jogging now
« Reply #5 on: September 09, 2009, 09:08:43 AM »
I put it back on a page but it still doesn't jog.
Are you sure it's not in MPG mode?
Re: No jogging now
« Reply #6 on: September 09, 2009, 09:12:14 AM »
I have put a led to know what mode its in. it WILL work in MPG mode with an mpg not not jog cont.
Please look at an edited reply above
Re: No jogging now
« Reply #7 on: September 09, 2009, 09:16:56 AM »
Now I'm confused after you edited your posts. If you have a Jog on/off button on the current page, and you're in the correct jog mode, it should jog.
Re: No jogging now
« Reply #8 on: September 09, 2009, 09:23:43 AM »
Hi i have now solved the issue with the clues you provided
I am using the fantastic Machscreen program
I checked the button properties for the jog button on an individual page it had global set to NO
On the page i have the button it is a global page "0" i changed the buttons properties from global Yes to global NO and now it is working
Phil
« Last Edit: September 09, 2009, 09:31:55 AM by Phil_H »
