Hello
Guest
it is
September 25, 2026, 02:51:05 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Wont run G code
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: Wont run G code (Read 23043 times)
bfairey
40
Wont run G code
on:
April 08, 2009, 09:56:58 AM »
It loads the Gcode ie Roadrunner but wont run it.
Which button do I push?
The PC is not connected to a machine.
Brian.
Carnoustie, Scotland
Re: Wont run G code
Reply #1 on:
April 08, 2009, 10:07:24 AM »
Is the RESET flashing?
ger21
6,295
Re: Wont run G code
Reply #2 on:
April 08, 2009, 10:07:58 AM »
Do you have all the axis setup in ports and pins?
bfairey
40
Re: Wont run G code
Reply #3 on:
April 08, 2009, 04:49:41 PM »
reset not flashing
port and pins set correctly
Re: Wont run G code
Reply #4 on:
April 08, 2009, 04:52:24 PM »
please attach your xml.
bfairey
40
Re: Wont run G code
Reply #5 on:
April 08, 2009, 05:10:32 PM »
The only error I found was under Config check
Output signal check
Pin for output found as not pins 1-9, 14, 16 or 17 unless using "modbus"
This is wrong.
Please comment.
Brian.
Re: Wont run G code
Reply #6 on:
April 08, 2009, 05:13:37 PM »
bfairey
40
Re: Wont run G code
Reply #7 on:
April 09, 2009, 04:31:12 PM »
Hood did you get my XML file?
Brian.
Re: Wont run G code
Reply #8 on:
April 09, 2009, 04:33:44 PM »
nope
bfairey
40
Re: Wont run G code
Reply #9 on:
April 09, 2009, 05:21:33 PM »
Try this
Brian.
Print
Pages:
1
2
Go Up
« previous
next »
